Old 6th December 2005, 06:40 PM   #1
hifimaker's Avatar
Question Best way to power a 12vdc fan from 25vdc for an Aleph30
I'm building an Aleph30 and wanted to include a low noise fan in the chassis.
The Aleph30 has a 25VDC powersupply and the fan is 12vdc at .06amps.
What is the best and easiest way to drop the voltage for the fan? Is a voltage divider needed or would a resister in series with the + slide of the fan work ok?
Thanks for the suggestions.
-David
Old 6th December 2005, 08:01 PM   #2
pinkmouse's Avatar
Wouldn't it be easier to use a 24V fan?
Otherwise just use a normal 3 pin regulator, though you may want to put a trimpot in the circuit to fine tune the speed.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 6th December 2005, 09:06 PM   #3
wuffwaff's Avatar
a simple series resistor will do. Normally 12V will be too much for really low noise. I would try 8 or 9V.
At ca. 45mA you will need a (25-9)/0,045=355ohm resistor. Power needed 0,045^2 x 355 = 0,72 Watt
You could try 330 or 390 Ohm resistors of 2 watts to be on the safe side.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 6th December 2005, 09:15 PM   #4
zlast is offline zlast  United States
Send a message via AIM to zlast Send a message via MSN to zlast Send a message via Yahoo to zlast
Default Fan
Put two 12volt fans in series...
none
Old 6th December 2005, 10:55 PM   #5
Phill is offline Phill  France
from the secondary
a bridge of diode
C : 01µF
LM317
Rv 5K + 240R
C : 200µF
and one can regulate speed
or
Instead of few fans at 12v, anyone try many fans at 7v?
Phill
small handyman
Old 6th December 2005, 11:06 PM   #6
The one and only
Nelson Pass's Avatar
I like this circuit. You can vary the fan speed, but it gives an
extra kick on turn-on to get the fan spinning reliably, and then
you can idle it at quite low speeds if you want.
Old 6th December 2005, 11:14 PM   #7
Banned
I think Mr Pass's method has got to be the best with the added
bonus of varying the speed and silent operation
Old 7th December 2005, 01:37 AM   #8
jackinnj's Avatar
simplest way -- without wasting any energy -- get yourself an LM3524 (SG3524) and PWM the fan circuit -- kind of an old circuit but National Semi has an application note which shows exactly how.
or if you are using a torroid -- just create another secondary by winding a few extra turns with #24 insulated wire around the core -- I did this with my LM4780 bridged amp which required a fan.
Old 7th December 2005, 08:36 PM   #9
Banned
oh yeah i like the second idea too if the transformer allows
you to do that if you make the winding with taps you also
vary the speed and the idea is intrinsicly efficient
thanks jackinnj
cheers
Old 7th December 2005, 09:21 PM   #10
Tweeker is offline Tweeker  United States
The simplest cheapest way I can think up to give regulated 12V is with a 180 ohm resistor and a 12V 1W zener. You could add a pot to this to give variable speed. The watt or two wasted here I dont think is significant in an Aleph.
Be sure your foil hat has a good low impedance ground.
12vdc power distro lovitz Everything Else 3 30th April 2008 05:46 PM
Aleph30 (and other Class-A amps) Hi-Lo Power Switch? Daveis Pass Labs 12 6th April 2006 04:10 AM
How to get +15v and -15v from 12vdc mbcouple Everything Else 15 25th June 2005 05:25 PM
Sprague 36D 35000uF 25VDC -10%/+100% kjunom Swap Meet 0 27th December 2004 08:30 PM
12vac to 12vdc what all do i need Big_Tires Solid State 5 1st September 2004 11:33 PM
Page generated in 0.09893 seconds (79.46% PHP - 20.54% MySQL) with 11 queries
