Forte Model 1A inputs max voltage
Hello,
Anybody here knows what the max input voltage for the Forte model 1A is? I'm trying to match it with a dac, and want to make sure I can get as much volume as possible out of the setup...
The dac I'm looking at is a bel canto dac 1 (I think it is a 2 volt output)
Double power is 3 dB more, 2 watts in your loudspeaker gives you 3 dB more sound pressure than 1 watt.
Double voltage is 6 dB more, from 1 to 2 volts is 6 dBV, from 2 to 4 is again 6 dbV.
From 1 volt to 20 volt is around 26 dB.
Input voltage of the Forte 1 (40 watts) was "about" the same.
Good thing Mr Pass built your 1A, not you. :clown:
