Hi all,
Due to my heat sinks,my friends and I have designed aleph-x integrated PCB layout.The board size is 310x102( mm ) and one channel's components in this board,please look into attached image file and give you suggestions.And your help will be highly appreciated. Cheers. Leo |
#2 |
Looks great.
Which program did you guy's use. I would sure like to make something similar. But i'm not used to pcb design software perhaps you could post the files for the pcb
air is analog |
#3 |
Hi Leo,
your layout looks good. I just have one remark: the space for the power resistors looks too small to me, 3W and 5W resistors are usually much bigger than what they look like on your board. Cheers, Bruno |
#4 | |
Cheers Leo |
#5 | |
Thanks for you suggestion,we have modified this. Regards Leo |
#6 |
Leo, your pcb layout looks very nice.
Would it be possible to get the files.
air is analog |
#7 |
Relayout the aleph-x 100W pcb,Would you advise for this?
#8 |
Hi Adams_Leo,
This is a large board. Laying out a serious high current circuit is risky and can take more than one turn to get things right - even for an experienced PCB designer. I would recommend wiring your amp point-to-point on perf board. Then you can move things around easily if you run into problems. I'm just trying to save you some money here. Board turns are expensive especially with big boards. GL |
#9 |
i've noticed that you use DXP for drawing the pcb. I'm also using DXP (Altium Designer 6.0). However i'm not able to find pcb footprints for heatsinks at all in the standard libraries. I see that you have them included in your board and i'm wondering if you could be so kind to send those libraries over? Wonderful job on the layout! Thx again, Kari |
#10 | ||
Leo Quote:
thanks Leo |
| AX100 100W Aleph-X Monoblocks | gl | Pass Labs | 634 | 26th January 2012 12:46 PM |
| Physical layout for integrated stereo GC | falcott | Chip Amps | 3 | 25th October 2006 10:02 PM |
| Rod Elliot 100W PCB Layout | bugbite2k | Solid State | 5 | 30th January 2002 05:32 PM |
| Page generated in 0.10399 seconds (78.14% PHP - 21.86% MySQL) with 11 queries |
