Aleph-X with JFET outputs
Old 29th November 2005, 06:26 AM   #1
kiwi_abroad is offline kiwi_abroad  New Zealand
kiwi_abroad's Avatar
Default Aleph-X with JFET outputs
Hi All,
Throughout the Zen articles by Nelson Pass, he kept suggesting that his designs were building blocks to be combined and matched together.To this end, I had the idea to insert power JFETS into the AlephX output stage. The image attached is a first stab, based on Nelson's cascoded JFET amp and the AlephX design. Please note I have not yet simulated this, although that won't be too far off. I'm sure the schematic has errors also...
I thought 'd run it by ther forum to see if this is a feasible and sensible enhancement to the AlephX.
The main issue is the JFET requires a -ve voltage on its gate, hence the 4.5V 'batteries' to produce the DC voltage shift. In the real world, these could indeed be real batteries (bypassed by signal caps). They won't need to produce any current, save the gate capacitance of the JFET. I fully expect this to cause havoc with the already troublesome DC output issues of the AlephX.
Any comments or suggestions...
By the way, where can I get a PSPICE model of the power JFETS Nelson is using??
Old 29th November 2005, 06:47 AM   #2
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Hi Kiwi,
Ive ordered 100 of these and assumed they would be drop in replacements on the X if I kept the rails to around 16V. Maybe I should make a normal X first.
Old 29th November 2005, 06:53 AM   #3
The whole idea of Nelsons article was he was running them with a gate voltage around 1 volt below the souce pin, hence giving it the 'Triode' like behaviour. It also allowed Nelson to use the lovely self biasing feature of a -ve gate voltage.
Unfortunetly, In the AlephX, unless we want to throw away a lot of voltage and power by having a large source resistor below the JFET, we must use some other way of producing the DC shift of the signal.
Perhaps someone else can see something I can't
Adrian
Old 29th November 2005, 06:45 PM   #4
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
As a practical matter, you have to throw away the voltage.
In this case, you lose about a volt on the Source resistor,
about2 to 3 volts on the JFET and about 2 volts on the
Mosfet, so figure on a 6 volt loss instead of the usual 2.5
or so. You can either ignore it, or you can make the negative
supply higher voltage.
Old 30th November 2005, 01:27 AM   #5
john-china is offline john-china
john-china's Avatar
Default why
why not use big capacitor (maybe 10u ,maybe 100u) instead of batteries ,? that is more simple .
big capacitor can cut off DC contact between two parts of circuit. also match your need.
Maybe i should not be lazy again
Old 18th March 2011, 03:15 AM   #6
JZatopa is offline JZatopa  United States
I know this is an old post but now that there are power jfets available I thought this thread had new relevance. Would the semisouth jefts fit the bill here?
Old 18th March 2011, 07:02 AM   #7
h_a is offline h_a  Europe
h_a's Avatar
Sure one can cook up a circuit with the Semisouth-jfets, their cost is, however, a different story
Hannes
High Octane phono preamp Wiki
Aleph-X with JFET outputsHide this!Advertise here!
Jfet input for Aleph 60? Dansk Pass Labs 14 22nd January 2011 01:34 PM
Aleph Mini with JFET input? Arie Pass Labs 11 21st March 2008 05:42 PM
Hum problem with jfet Aleph 3 (babbelfish) cviller Pass Labs 88 16th February 2007 06:56 AM
Two outputs from Aleph P 1.7 loovet Pass Labs 4 17th April 2006 04:04 PM
Bi-amp with Aleph P bal. and unbal. outputs Sony Pass Labs 3 21st December 2004 07:09 PM
Copyright ©1999-2017 diyAudio
