#21 | ||
So for example if you had an unbalanced output driving the line with say, 1 volt, and you converted to balanced by driving the second line with the same signal only inverted, you'd measure +1 volt on the + line and -1 volt on the - line. If you converted to a balanced output using the passive solution, you'd measure +0.5 volts on the + line and -0.5 volts on the - line. And not to be too much of a stickler here, it's not the line that rejects the noise. That's done by the differential input. What balancing does is help keep common-mode noise common. If an interference field impinges upon each line identically (and techniques such as twisted pairs helps assure that they do impinge identically), if the impedance of each line with respect to ground is the same, then the voltage induced across each line will be the same in terms of magnitude and polarity and subtracted out at the differential input. If the impedances are not the same, then the voltage induced across each line will be different, and the differential input will amplify the difference between the two. Quote:
But hey, rightly or wrongly, it's still a lot of fun. se |
#22 | |
se |
#23 |
Steve,
thanks for sharing!
Greets, Bernhard |
#24 | |
![]() Awwwww, I didn't really mean it. You can use it too. I love ya, ya big lug. se |
#25 |
Steve
Being of limited knowledge when it comes to this stuff, what would the circuit look like to convert an amp to a balanced input using your balanced output. Bob2 |
#26 | |
The one and only
that would create this effect. The - line does not carry signal, only noise. |
#27 | |
So how does it really compare in reality, passive versus active retriving of a balance line?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#28 |
Why add more circuitry to convert unbalanced to balanced when the preamp in question already does this? If you feed the balanced output of the preamp to the balanced input of a power amp, you are good to go.
You could go to http://www.jensen-transformers.com/ln_in.html and get one of those if you absolutely must have the unbalanced to balanced conversion prior to your preamp. But for the record, I wouldn't bother. Erik |
#29 | |
At the input, it's not just a matter of balancing the impedances of the two lines, but also of providing a differential input so that any common-mode noise on the lines can be rejected (which is the raison d'etre of balanced interfaces in the first place) and depending on the existing input circuit could involve much more significant changes in the circuit itself rather than just tacking on a few parts. So without a specific circuit to work from, there really is no generic answer as with outputs. se |
#30 |
Banned
im going to try the esp projects. and see how they work.. is there a sound difrence between
balanced line in xlr compaired to rca in .. will i hear the difrence ..? |
| Balanced zen line stage | hcbonfim | Pass Labs | 17 | 4th June 2007 09:17 PM |
| Balanced Line to Mic Pad DIY?? | Zero Cool | Instruments and Amps | 2 | 23rd February 2006 04:38 PM |
| Balanced Zen v5 + balanced Zen line stage | Adrie | Pass Labs | 0 | 30th May 2004 05:27 PM |
| Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 06:18 AM |
| Balanced line stage | lykkedk | Pass Labs | 1 | 5th December 2002 07:36 PM |
| Page generated in 0.11395 seconds (85.37% PHP - 14.63% MySQL) with 11 queries |
