I just rounded up the parts for the BOSOZ. I ordered the Diode bridge from Digikey (for the power supply) #2KBP02M-ND. It appears to be a 4 pin rectifier and my PCB is set up for a two device. Any suggestions?
Also I am planning to make a wooden case for the Preamp. Does it need a metal case around it for shielding? |
#2 | |
Steen. |
#3 |
Thanks for replying.....I was confused! I figured out where the bridge diode goes.
Do you see any problems with a wood enclosure? |
#4 | |
Someone else with knowledge on this? Steen
#5 | |
Some experiments with some of my own DIY gave an enlighting view and a somewhat confused sound. Greetings, Harry |
#6 | |
Is that sounding any better? Okay I know you can go to great measures to shield out EMI and so with MU-metal! I never heard of the wood thing, though. Thanks for replying, Harry I am sure our friend Kennethrl, is happy too As for preamps, I have had the best results connecting the circuit GND to the chassis. That would be more ore less useless, with a wooden chassis.Steen
#7 |
I wasn' t planning to put the preamp directly on the amp. It will be about 3 feet away. So, this can effect the sound? I guess the power supply should be shielded?
#8 |
Kenneth, 3 feet away makes you pretty safe
Normally you dont have to shield the psu from the circuit itself. Just put the trafo in one corner and the preamp board itself in the opposite corner, so to speak. The more dist. between the two, the better!If you need more info, speak right out. Happy building and best of luck Steen
#9 |
Thanks for the help!!
I have another question I am going to have rotary switch to select inputs (CD, radio,etc). My local parts supplier told me that the negative inputs are put together(for both channels) and the positive are separate in the switch (it is a 3 pole 4 position switch is this a common and is it the right way to go? |
#10 | |
If you do have a balanced source, you do not want to tie the neg. signal to ground! Please tell me a bit more If you have only single-ended input, you just put a jumper in the board from -in to gnd! Right and left channel are kept seperate.Steen
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Bosoz | lawbadman | Pass Labs | 5 | 14th July 2003 02:10 AM |
| 10K Pot for the BOSOZ | raincheck | Pass Labs | 13 | 20th September 2002 06:22 PM |
| Page generated in 0.10964 seconds (78.23% PHP - 21.77% MySQL) with 10 queries |
