Old 13th October 2002, 01:09 AM   #1
Smile Another thread on speakers for the ZV4.
I ‘m building myself three zv4 amps. Next, I need a nice set of speakers to go along with it. I have narrowed down the candidates to 3 speakers. (1) The e.j.jordan jx92s full-rang driver in there standard transition line enclosure. (2)The North Creek Okara II Bookshelf Monitor and finally the Ariel. My room is small 9’ x 20’ and I will be placing it n the long wall, because that’s where they fit. Let me write down a little about each one of these for people who do not know of these speakers.
1.) The e.j.jordan jx92s full-rang driver in there standard transition line enclosure is by far the cheapest of the three. The drivers can be gotten in the U.S. for $100 each. It is also one of the easiest to build. The cabinet is 12” w and 4” deep, so if there is a problem with the wood working, as I know there will be, I can just fill in the side with fiberglass resin. The short comings of this speaker are that the driver is only a 5” driver. It has a sharp roll-off after 15 KHz. I have been told by many people that the bass on this driver is very good for its size because it is transition line. Konus Audio systems also make these speakers under the name “Essence” for the price of $3,500 per pair. At that price I would expect them to sound good. To spite this speaker’s low sensitivity of 88db Konus sells this speaker with there 50 watt amps. It is my 1st chosse at this point. If anybody wants a cabinet drawing I can post them.
2.) The North Creek Okara II Bookshelf Monitor uses the same drivers as the Ariel. Its cabinet is a little boxier then the e.j.jordan jx92s. This system has a nice full range response and its sensitivity is bout the same. My major complaint about this speaker is that North Creek has now decided to sell there cross-over in epoxy so I can’t build anymore of these without going throw North Creek nor can I try different caps and such. I’m not saying the quality of there crossover is bad; it’s realy very nicely made with all quality parts.
3.) I think most people reading this thread know about the Ariel. The cabinet work is a lot harder then the other two speakers. It cost a little more then the North Creek Okara. The main thing this speaker has going for it is it’s sensitivity of 92db. Mad_K post on the “ZenV4, SOZ, or Original Zen for Ariel?” thread has put me off of the idea off using the Ariel because the Aleph 3 and zv4 share nearly the same output stage. They have the same constant current Source, the same bias level (2 amps) and almost the same power output (25watt, 30watts). I still haven’t ruled out any of these possibilities. However the Ariel has drop down to the bottom of my list. This speaker was probably made for an amp that has almost no bass control. That’s probably why it sounds bad with some of this higher power ss stuff.
I would like some opinions from people who have herd any of these speakers. It would be nice if someone has herd two of the three speakers on this list so they can make comparisons between then. However, I would seriously doubt that anyone has ever gotten any of these speakers together because there all DIY speakers, so all opinions are welcome.
I have looked at pretty much everything the DIY community has to offer, with the exception of the long awaited claw by nelson pass, and these are the ones that seem to stand out in my head as keepers.
Old 13th October 2002, 02:15 AM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
i like the idea of small satelite speakers with seperat amplifiers to power each driver or pair of speakers ex z4 for the satelite speakers and a pair of nice balanced class ab speakers powering a pair of ported subs.
Old 13th October 2002, 04:27 AM   #3
The one and only
Nelson Pass's Avatar
The Claw has recently been spotted along the
American Canyon. We are planning another safari
soon.
Old 13th October 2002, 04:37 AM   #4
Banned
SAY WHAT..!
Old 13th October 2002, 08:26 PM   #5
The one and only
El Pipe-O and his mate have already been captured tho,
and you'll see them on exhibition in a couple of weeks.
Old 13th October 2002, 09:00 PM   #6
macka's Avatar
Yes,
I expect you would need to be in an area something the size of the American Canyon to hear, or even feel El Pipe-O or The Claw.
What must the local natives think with This mad professor going up into the hills with a pile of lumber and a few 24" woofers in the back of his pickup not to mention the lights dimming in the immediate vacinity!
Cheers
macka
Old 14th October 2002, 01:04 AM   #7
These are the cabinet drawings for the e.j.jordan jx92s full-rang driver. See how thin it is.
Old 14th October 2002, 03:17 AM   #8
sianturi's Avatar
Hajdu,
Regarding the Ariel, you'd probably missed the DF. I think Zenv4 has a lower DF than Aleph3 does. And DF plays an important role in Ariel (according to Lynn Olson).
Why don't you ask jh6you? I think he is still using Ariel with (baby) Zv4.
Regarding the OkaraII, you can build an alternate version of it using different tweets (Hyquphon OW II) and different crossover (same mid). Visit www.murphyblaster.com if you'd like to see.
cheers,
The Great Saiyaman
Siapa bertelinga hendaklah ia mendengar... (Mat 13:9)
Old 14th October 2002, 03:48 AM   #9
frugal-phile(tm)
planet10's Avatar
The Jordan is one fine speaker. It gets even better if you XO it over to a tweeter (can be done right off the bat or after you have lived with them a while). This thread is on just such a beast.
And i'm with JasonL that a mini-monitor (as i'd classify the Jordan in the TL) with active subs is the way to go with any system.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th October 2002, 05:33 AM   #10
planet10,
What amp would you pair this speaker with ?
An other idea I had is pairing up the Aleph30 with the regulated supply for 10watt son of zen in fig 6 of Nelson’s Zen Variations - part 3. It has the right voltages. This should stop the buzz that everyone complains about with the Alephs.
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 10:27 PM
The Definitive Concrete Speakers Thread. Spasticteapot Multi-Way 2 26th January 2007 12:06 PM
Brett's Horn Speakers ( Moved from Tannoy Gold Thread) cyclotronguy Multi-Way 10 28th October 2004 08:18 PM
Hurricane speakers- split from AXB thread ingvar ahlberg Pass Labs 4 6th March 2004 06:23 PM
Page generated in 0.11373 seconds (81.82% PHP - 18.18% MySQL) with 11 queries
