Hello
the radiators of my Aleph 5 are a little small ,and I can't any more modify them with an ambient temperature of 20°C, the radiators are with 57° . but in summer, it makes 30°, ==> 67°C. Which is the tolerance? before it leaves in smoke and I would like well that the components last a long time! thanks Phill
small handyman |
#2 |
Nelson has a rule of thumb (so to speak) about how long you can leave your hand on the heatsink before you have to snatch it away with a squeak of pain. I don't remember the actual sequence, but I'm sure five other people will post it before I finish typing this post.
I'm a little more conservative than Nelson regarding heat. I like to be able to leave my hand on the heatsink forever. In a situation such as yours, I'd recommend fans. Or you could go to water cooling... Grey |
#3 |
Grey, is this what you were thinking of?
Nelson has previously indicated the following: Blimey hot is 10 sec hands on = 45c Crikey hot is 5 seconds = 50c Bloody hot is 2 seconds = 55c X*?@! is 60c Keep output mosfets at 75-80c max |
#4 |
Thank you
there are probes of temperature which function very well! My grandfather was a baker.... it left the breads the furnace with its hands... and I make similar...it is true! it is not good for my fets... a temperature lower than 45 °C would be well, no ? Phill
small handyman |
#5 |
50-60°C for the heatsinks is OK. You could also measure directly on top of the fets (the plastic). This is a bit difficult but normally if you measure below 80°C you don´t need to worry. Fets have different feelings about what´s hot or not as we humans. For verry hot summerdays you can always put in a switch to reduce bias by 10-10% William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#6 | |
thank you, it is a good idea! Phill
small handyman |
#7 |
Banned
Guys i have tempareture problem
the heatsink temperature is at arount mid 40degreesC but the probe on the plastic body of the device is reaching 100degreeaC and rising when i hit the off switch whats the problem, i dont use heatsink compound should i screw the device tighter, or is it something else |
#8 | |
diyAudio Moderator Emeritus
Putting heatsink compound is the most effective way to make maximum contact between transistor body plate and heatsink surface. Using grey rubber silicon insulator makes the look neater, but I still think the heatsink compound is better (but looks messier). You must have known this, because you're a CLASS A SPECIALIST. And since you don't use heatsink compound, you must be using some kind of advanced technique. Could you share what method do you use to ensure maximum heat tranfer from transistor's body to the heatsink, that do not use heatsink compound? You CNC-micro grinding all the contacting surfaces? |
#9 |
Banned
HI lumanauw
thanks a lot , ill try putting some heatsink compound on all sides of contact and see what happens i am still learning one more thing which is better regular washer or silicon rubber this will improve heat transfer to heatsink dont you think? thank you so much lumanauw cheers |
#10 |
Phill, paint your heatsinks black.
Regards |
| Operating Temperature of KT88? | OaG_sGm | Tubes / Valves | 5 | 16th January 2009 03:40 PM |
| Max safe operating temperature for transistors inside modified factory amplifier | azzajonesy | Solid State | 8 | 8th October 2008 01:00 PM |
| Safe operating temperature. | ronjodu | Chip Amps | 7 | 31st May 2007 01:11 AM |
| Ideal operating temperature for transistors? | starbase218 | Parts | 6 | 30th December 2005 07:03 PM |
| aleph 2 temperature | MikeZ | Pass Labs | 18 | 15th November 2003 02:16 AM |
| Page generated in 0.20381 seconds (49.31% PHP - 50.69% MySQL) with 10 queries |
