Old 19th February 2006, 06:38 PM   #731
Anyone get the PE trans. working yet? I am about to fire mine up with 2 33v zeners on the + and one 15v zener on the - . I am not sure if I need to change the values of R5 and R6? I guess it might be tuned for maximum smoke. Fingers crossed.
Old 20th February 2006, 03:01 AM   #732
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
What resistors are responsible for gain? Would that be R18 and R19? What are side effect of changing these since my understanding is that they regulate amount of feedback? I understand that on original Bosoz R15 regulates gain, but on X ccs Bosoz there is no such a resistor. Is there any problem lowering gain to very low level?
Old 20th February 2006, 03:54 AM   #733
Account Disabled
I think another way is possible,
by adding source resistors just under the Q4 and 5.
Details could be adviced by X-BOSOZ experts . . .
jh
Old 20th February 2006, 09:30 PM   #734
No, but I'm watching you carefully.. also with fingers crossed. Are you on the 14-0-14 taps for the - ?
Old 20th February 2006, 11:31 PM   #735
Ok, I got both + sides working with 2, 33v zeners. I changed r5 to a 1/2w and added a seccond 221 Ohm 1/2w. I changed r5 because I kept smoking it, now it seems to work. 70.04v on both boards. I have not got on the - side because I just got a box with 40 9610's from ups I was thinking of using 16v from the trans. not the 14. I will report back when I find out.
Old 21st February 2006, 12:57 AM   #736
Thanks for the info...
As it was once explained to me, learning is discovery~
but I am ALL DISCOVERED OUT!
see my posts on smokey output boards:
Oops
and funky voltage on a no brainer PS:
Huh?
I just can't take another challenge. Thanks for posting!
Old 21st February 2006, 02:56 AM   #737
I know what you mean. I have to learn all this stuff as I go to.
Old 25th February 2006, 12:56 AM   #738
SteveA is online now SteveA  United States
I'm using Kari's design which runs on+60/-12V and have gotten the correct voltages from this transformer. If this is the same transformer I have it has
1) 55-0-55
2) 16.2-0-16-2 and
3) 14-14 (no centertap)
I used 1) for the +60 and 2) for the -12 and got +59.7 and -11.5.
SteveA
PS, haven't fired it up yet
Old 25th February 2006, 01:04 AM   #739
I am using the 55 and 16. Two 33v zeners on the + and one 24v zener one the -. I get 70.03 and -20.2, I might be off by a few tenths as I do not have my notes with me. That is as far as I have gotten so far. I have to many projects going
Old 25th February 2006, 08:44 PM   #740
I understand the switch to 1/2 watt in positions r5 (and R6?) but don't understand "and added a second 221 Ohm 1/2w".
For use with the PE tranny, I am placing (2) 33V 1w zeners in ZD+1 and ZD+2 with jumps at ZD+3 and ZD+4. On the - side, one 15V 1w at ZD-1 and jumps on ZD-2, ZD-3, and ZD-4. If this is not correct, would somebody let me know before the smoke gets out.
Thanks!
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 02:57 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 12:55 AM
Bosoz lawbadman Pass Labs 5 14th July 2003 02:10 AM
10K Pot for the BOSOZ raincheck Pass Labs 13 20th September 2002 06:22 PM
Page generated in 0.10909 seconds (81.41% PHP - 18.59% MySQL) with 11 queries
