My Take on X-BOSOZ - Page 2 - diyAudio
Old 7th November 2005, 07:11 PM   #11
mpmarino's Avatar
Have it made..and they will come
Crazy Yankee.
Old 7th November 2005, 07:24 PM   #12
ble0t is offline ble0t  United States
ble0t's Avatar
Looks really nice!
I'm not sure what the tolerances of the PCB manufacturer are, but I noticed that the upper pad of R5 is awfully close to the trace above it.
Keep up the good work
gravity always wins
Old 7th November 2005, 07:38 PM   #13
Russ White's Avatar
Send a message via Yahoo to Russ White
Thank you,
How is this?
Less pulp more juice Twisted Pear Audio.
Old 7th November 2005, 07:43 PM   #14
Russ White's Avatar
Default Fixed an oops. :)
Accidently had R3,R4 as 21.1R instead of 22.1R
Fixed:
Old 7th November 2005, 07:44 PM   #15
Russ White's Avatar
Default Fixed schematic
schematic:
Old 7th November 2005, 09:22 PM   #16
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Nice work as always Russ But why the layer change for the traces from C4/C5 to CPxx ?
EDIT: Same question for the trace from C1 through R9 to R5?
/U.
Old 7th November 2005, 09:34 PM   #17
Russ White's Avatar
/U.
Thanks for pointing that out to me, i missed the first thing simply becaue I have been looking at it too long I think. It is now fixed. Picture will be in next post.
The second is not exactly correct, but its hard to see, so I have attatched a zoomed image.
Old 7th November 2005, 09:36 PM   #18
Russ White's Avatar
Default Better optimized traces.
Thanks Nisbeth:
Old 7th November 2005, 09:44 PM   #19
BrianDonegan's Avatar
Looks like there is trace-doubling between the pins of the references as well (top and bottom).
Old 7th November 2005, 09:53 PM   #20
Russ White's Avatar
That was actually intentional. I built a version of that part in the library with those two pins coupled because the datasheet says so. And I wanted to be sure it was the same on both sides since I knew it would have traces running to/from it on either side. But I could easily remove one trace. Not sure it matters..
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 03:57 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 04:15 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 01:55 AM
Bosoz lawbadman Pass Labs 5 14th July 2003 03:10 AM
10K Pot for the BOSOZ raincheck Pass Labs 13 20th September 2002 07:22 PM
Copyright 1999-2017 diyAudio
