My Take on X-BOSOZ - Page 142 - diyAudio
Old 12th July 2012, 06:19 AM   #1411
HIPCHECK's Avatar
Brian and Russ, thank you so much for support on these PCB's way past the "fashionable" period.
Answer was that obvious I guess.
If a inch of duct tape will fix it, 3 feet should fix it for life!!!!
Old 12th July 2012, 01:48 PM   #1412
Hello,
Are any more of the X-BOSOZ/PSU PCB's available?
Old 12th July 2012, 04:40 PM   #1413
HIPCHECK's Avatar
I bumped a wanting to buy pcb thread for about a year IIRC before I got mine.
Steve
Old 12th July 2012, 07:55 PM   #1414
HIPCHECK, thank's!
Lots of waiting projects to finish in the meantime
Old 19th June 2013, 01:05 AM   #1415
still4given's Avatar
I started one of these when Russ and Brian first started offering them. I believe I was part of the first batch. Anyway, I never finished it. I got the PSU completed and the X-BoSoZ competed except for installing the FET's. When I realized I would need an expensive volume control circuit, I put it on the shelf. Well I have just returned to the hobby and am anxious to complete some of the projects that I left undone. This is one of them. I have looked around and it seems like not many of the X-Bosoz's were built. I see also that Twisted Pair stopped dealing with them. So I'm asking if any of you have built one and if you are still using it. The main reason I got interested in this is because I had just finished an Aleph X and wanted a balanced Pre to go with it. So what do you think? Is this a worthwhile preamp to complete and is there a good attenuator to go with it that is a little less complicated?
Thanks, Terry
Old 19th June 2013, 02:46 AM   #1416
HIPCHECK's Avatar
Looks like you got your AX working and got the diy bug again?
As for this pre-amp, I will let you know, I have one almost done. I will run with my Mini-A now, and later a diy AX.
Old 19th June 2013, 03:03 AM   #1417
What are you using for the attenuator?
Old 19th June 2013, 03:34 AM   #1418
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
Loved the Pre-amp. Used Russ' switching attenuator. Basic problem I could never resolve was sensitivity to static or transients. Changed the FETs many times .
Old 19th June 2013, 03:38 AM   #1419
HIPCHECK's Avatar
I have an Audio Alchemy DLC pre-amp. It should handle the switching and volume controls for me.
I would think all the digital stuff would not really be needed, however, pga volume control kits are more common now, and could be had much cheaper than when this project first started.
Steve
Old 19th June 2013, 07:57 AM   #1420
wuffwaff's Avatar
Im still using my X-BOSOZ into a pair of Aleph-X and build another one for a friend.
In my amp Im using a balanced attenuator (is somewhere in the Borbely papers) which is quite simple (a 24-step switch and 46 resistors) but you cant buy it ready made (at least I didnt find a supplier). You can have a nice low output impedance with these but it will be dependend on the volume setting.
The other I build with a remote controlled volume control from Dantimax (for balanced amps)
William
een ooievaar is geen konijn want zijn oren zijn te klein!
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 03:57 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 04:15 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 01:55 AM
Bosoz lawbadman Pass Labs 5 14th July 2003 03:10 AM
10K Pot for the BOSOZ raincheck Pass Labs 13 20th September 2002 07:22 PM
Copyright 1999-2017 diyAudio
