Old 13th May 2006, 11:12 PM   #1131
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by Assesears
Need some help/advice here, I've developed a fault on the left channel of my BosoZ which is large amounts of hiss out of the speaker, changed over channels of source and amp, swapped over power supply and pots, changed out diodes, checked for cold solder joints and still no joy, hope its not the fets. Any help/idea's appreciated.
Cheers Bruce
Humm yes mine to has some hiss. I can't do any thing about it at the moment as im moving but when i move i can listen to it more closly and see what i can come up of it.
Old 14th May 2006, 12:43 AM   #1132
cjd is offline cjd  United States
I'll be able to let you know how mine sounds shortly.
Just have to connect the source to the pre and the pre to the amp and it's ready to go!
Munching some home made something or other dessert that's delicious though, so gotta finish that first.
C
Old 14th May 2006, 01:54 AM   #1133
Well...
After one stupid mistake (power supply backwards, somehow, after checking it 3 times) it all works. Blew the 22uF cap pretty quickly, so hopefully no harm done beyond that. Seems to be none. Only one channel, so I'll just add another part to the order I need to place.
It's still very quiet. Changing to a source that puts out more and it picks up distortion still. So I must have something amiss in my amp circuit. I'll get the schematic to you guys soon, I've been updating it with everything.
The Joshua Tree works fine, but there is one spot that has a very distinct "pop" when one relay switches on. I haven't tried to isolate which "side" it's on, and I haven't tried the other board yet.
Otherwise, it's quiet, and very clean, when it's playing within the range where it works well. No hiss that I noticed. And a definite improvement over running the X-GC with single ended input straight in.
C
Old 17th May 2006, 11:39 AM   #1134
Vigo is offline Vigo  Sweden
Vigo's Avatar
Can you destroy the fets if you try and mersure the resistens betwen the legs without the power connected?
To play with OP-amps in audio is like playing card with devil, you can never win.
Old 17th May 2006, 11:50 AM   #1135
Russ White's Avatar
Send a message via Yahoo to Russ White
Hi Vigo,
FETs typically are extremely sensitive to ESD. It is always wise to be very cautious about grounding yourself very well while working with them. Wearing a grounding strap while handling FETs is a good idea. I usually just make it a habbit to put mine on when I start to work on my electronics.
I have killed a dozen or so FETs just by walking across a room getting something and touch a trace connect to the gate of a FET before grounding myself.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 18th May 2006, 02:12 AM   #1136
Russ, do you have a thread or place where you're supporting the JT? I'm having definite issues... no solder problems that I've found going over it with the magnifying eye glasses.
C
Old 18th May 2006, 02:58 AM   #1137
Russ White's Avatar
Hi C
That thread is here:
http://www.diyaudio.com/forums/showt...119#post848119
And the last few posts , may help you out.
Also note that the attenuator will give you a pop in a couple spots if there is any DC in the signal. The more DC offset the more the pop. This is actually common for switched attenuators (not just relays). The best way to eliminate it is to eliminate the DC.
It is common to forget about DC offset on the inputs of a power amp.
Cheers!
Russ
Old 4th June 2006, 07:20 PM   #1138
how many gain gain for this pre-amps ?
Can it use as headamps ?
Old 13th June 2006, 02:27 AM   #1139
cfbuck is offline cfbuck  Canada
Default Ready to test Power Supplies
Russ,
I'm a raw novice at electronics and I have just soldered up my Power Supplies for the XBOSOZ kit. I have the Avel transformers. I will wire them as follows:
Positive
- outputs - red/orange shorted together,
- Yellow to AC+1,
- Black to AC+2
- 120 VAC inputs - Violet + Blue to Neutral
- Brown + Grey to Hot
Negative
- Yellow to AC-1
- Black to AC-2
I noticed in the post listed below in which you were illustrating how to measure the voltage on both +ve and -ve outputs, that you had two components mounted on the bottom of your ps board.
http://www.diyaudio.com/forums/showt...885#post856885
What were the components, where are they mounted and what do they do?
After powering up the board, and measuring the DC voltage, do I have to short each capacitor with a resistor to unload it for safety? If so, what is the recommended resistor size?
TIA, Fred
Old 13th June 2006, 03:06 AM   #1140
Russ White's Avatar
Hi Fred,
The components you see on the bottom are 10K 3W resistors between the capacitor leads. I used them to drain the capacitors during unloaded tests of the power supply for safety. When you have the power supply connected to the preamp it will always be loaded since the circuit is class A. So for normal use they are not really required, but they certainly don't hurt either.
Your transformer wiring appears correct as described.
Cheers!
Russ
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 02:57 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 12:55 AM
Bosoz lawbadman Pass Labs 5 14th July 2003 02:10 AM
10K Pot for the BOSOZ raincheck Pass Labs 13 20th September 2002 06:22 PM
Page generated in 0.13444 seconds (76.54% PHP - 23.46% MySQL) with 11 queries
