#101 |
How much space do the output caps have? abd what is the pin distance for them?
How do you want to heatsink the fets? |
#102 | ||
If you look at it, there is a "Twisted X" in the middle Cool.Quote:
Steen.
#103 | |
![]() /U. |
#104 | |
Steen
#105 |
Allright, you win
![]() /U. |
#106 |
just saw the your pcb layout tonight
did this months ago may or maynot be helpful. based off metalman's schematic top Ground plane very close to similar track lenghts (for symmetry) but doesn't look it.
Indecision makes the world gone round. Maybe |
#107 |
Ok here is the PCB so far..
You could use a vary wide variety of output caps either axial or radial. You could even use something like a high quality axial bipolar electrolytic bypassed with 1-10uf film cap if you chose.
Less pulp more juice Twisted Pear Audio. |
#108 |
No sure if this is a big improvemnet or not, but I added a ground plane with a single connection to PGND at the GND connector.
#109 |
Ignore the last PIC it has a problem with the GP
Here is the correct version:
#110 |
Russ,
I had a closer look to the layout this morning and if you don’t mind I would like to point a couple of small things I would do different: R12/13 should finish as close as possible to the gates of the FET. I think is doable if you have those resistors in an upright position and moving the red traces a bit downwards. You have fastons on the input signal and both pins seem to connect to the input. In my opinion one should be ground to properly terminate the ground input to the pcb. I myself will not use the faston connector for the input but of course that’s optional. I guess that more important that a ground plane is to have a correct star grounding for the input. I might have some other suggestions but that will take me a while to look over the schematic and layout.
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Bosoz | lawbadman | Pass Labs | 5 | 14th July 2003 02:10 AM |
| 10K Pot for the BOSOZ | raincheck | Pass Labs | 13 | 20th September 2002 06:22 PM |
