#1001 |
Banned
I need help with the x-bosoz
mine is fried and another psu down the drain I was getting 20V - and 35V positive. what have i done wrong ? im looking at the xcel sheet that they have put up on there site and its part for part.Pic's can be posted if needed. R4 on the other boards is now toast
#1002 |
Jason, it sounds like you installed another diode backward which probably toasted R4. You likely need to replace R4 and the diode(s).
Less pulp more juice Twisted Pear Audio. |
#1003 |
Banned
No it-s in exactly the same way as the psu shows it.
#1004 |
When I was getting the low voltage on the positive side, it turned out to be my mistake in hooking up the transformer. One of the primary connections was not tight, so it was overloading and dropping below the required voltage for the regulator to have any effect. I would suggest carefully (these are dangerous volatges.) checking voltages upstream of the zener/FET to make sure you are not starving the regulator.
Only other thing I can think of is making sure the 610 and 9610 are not switched. Craig |
#1005 |
Banned
This picture is exactly how i have mine built.
#1006 | |
Jason, we all know how the circuit should look. A picture of yours might help.
#1007 | |
Banned
I dont want to be rude, BUT my board is exactly part for part location for location and polarity for polarity. |
#1008 |
Mark Kravchenko --- www.kravchenko-audio.com
Not to say anything bad about your skills. But an extra set of eyes never hurts when your dealing with a lot of small parts. Been down the same path your on more than once. Everytime someone will walk in and spot the problem in 5 minutes.
Mark
Mark |
#1009 |
Banned
The transformer is connected like this..
Positive rail. white/oranged shorted to gether to get voltage of 60V it is a 2 x 30V Yellow goes to AC+1 Black goes to AC+2 Negitive rail The other transformer 2 x 12V orange/white shorted again to get 24V Yellow goes to AC-1 Black Goes to AC-2 I can post a picture tonight when i get home I hope i didn't ruen any thing.
#1010 |
Close up pics of the top and bottom would be ideal. Did the second PS work until you hooked it up to the pre?
Twisted Pear Audio |
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Bosoz | lawbadman | Pass Labs | 5 | 14th July 2003 02:10 AM |
| 10K Pot for the BOSOZ | raincheck | Pass Labs | 13 | 20th September 2002 06:22 PM |
