My Take on X-BOSOZ
My Take on X-BOSOZ
Old 7th November 2005, 09:31 PM   #21
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
Default fixed dupe traces
Also fixed a couple minor placement issues.
Less pulp more juice Twisted Pear Audio.
Old 8th November 2005, 12:35 AM   #22
ble0t is offline ble0t  United States
ble0t's Avatar
Looks nice...gotta love the symmetry of an 'X' design
gravity always wins
Old 8th November 2005, 11:03 AM   #23
Panelhead is offline Panelhead
Default Dumb questions
First of all, thanks for putting this together. Iassume sometime in the future you will offer PCB's to build.
Do most use 60 - 80 volt rails for this circuit? Never could understand why the preamp rails are so high. Have a power amp whith 13 volt rails, seems the rail voltage should be the other way around.
Also looking at the IRF610 I originally thought of getting some IR brand from digikey. Then found some Samsung brand. Does everyone use IR type for the BOSOZ type circuits?
A friend tells me that IRF510 will work in most circuits using IRF610 and sound better. Think it is more as a driver application, but may try. The one at the bottom may be a place to start.
I will have to try this, been using the same circuit for line stage for a couple years. Time to give something else a listen.
George
Old 8th November 2005, 11:27 AM   #24
steenoe is offline steenoe  Denmark
steenoe's Avatar
With mosfets, yes. Running the higher railvoltages gives much improved performance. Better linearity in the audioband and less noise.
IR devices has some of the lowest input capacitance. Look for the Ciss value in the datasheets. The lower the better. (Higher Ciss, gives more high frequency distortion.) The 510 and 610's are just different in rating (volt/amps) they are fairly similar otherwise.
You might be able to find devices that are just as good, but I havent yet
Steen
Old 8th November 2005, 12:23 PM   #25
eLarson is offline eLarson  United States
eLarson's Avatar
Default Re: Dumb questions
George,
I don't know about "better" but I can say that I've tried it with IRF510's (non-Xified BOSOZ with CCS) and also IRFD110's and it sounded fine with either one.
Knowing that in my system I'd never need more than 1V out, I used lower rail voltages, but also smaller drain resistors. (CCS in the source legs) As a result the operating point of the MOSFETs were more or less the same as in the article.
eL
Would a woodchuck bother to chuck MDF?
Old 8th November 2005, 01:48 PM   #26
Russ White's Avatar
Default Request for help. :)
Hi folks,
First I want to thank everyone for their kind words and helpful tips.
Now I need a little help with this circuit. I am not sure about ratings of certain parts, especially the resistors.
Particularly:
R3, and R4
R1, R2, R6, and R7
It looks like the other resistors can be standard .25W metal film types correct?
Also what voltage rating should C1 be 100V?.
Also I plan on resizing C2 and C3 to be 25mm diameter and 10mm LS which should fit most common snap-in 100-200V 1000uf caps. Right now it is set up of 7.mm straight lead types.
Any help with these details from those familiar with the circuit is great appreciated.
Cheers!
Russ
Old 8th November 2005, 02:43 PM   #27
thomasfw is offline thomasfw  Hong Kong
Dear All,
I also interested in this project.
I have done a PCB layout with single side.
After that I have stopped because of the "Volume
Design". I can't figure out which is "Cheap" , "Easy"
and "Best Performance" !(digital,traditional etc.,)
Thomas
Old 8th November 2005, 02:45 PM   #28
Sorry !Forgot the image !
Old 8th November 2005, 07:31 PM   #29
metalman is offline metalman  Canada
metalman's Avatar
Russ,
In my circuit, I used a single 1/2W resistor where you have split it to two resistors (R3 and R4). I believe you can use 1/4W with your circuit.
I used a single 5W resistor where you are using R1/R6 in parallel. For R1, R2, R6, R7 I would recommend 3W rated resistors as a minimum.
As to C1, its voltage rating will depend on the value of your negative rail voltage, which can be in the range of 10-20 volts. I don't think you will need a 100V rated cap there.
Lastly there is one set of resistors missing, which I included when I built my preamp, but missed including on the schematics. Q2 and Q3 need 221 ohm gate resistors in the connection to the voltage references. (My Bad ).
Otherwise it is looking great.
Cheers, Terry
Old 8th November 2005, 08:43 PM   #30
Default gate stoppers and another dummy question
Plan on using pots to control volume in mine. Do they need to be 10K? Seems that the input capacitance was high enough that a 10K pot was recommended to prevent high end roll off.
Have several 25K laying around unused. Hate to buy more to use here.
Also, output coupling cap selection. What is the range of dc seen here? If it is real low, may try to use some output transformers to do the balanced to single ended conversion. Prefer iron to caps where possible. Do not want to use both.
George
My Take on X-BOSOZHide this!Advertise here!
To BOSOZ or not to BOSOZ... please comment. spence Pass Labs 4 27th February 2012 02:57 AM
Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? promitheus Pass Labs 87 19th February 2006 03:15 PM
X-bosoz vs. CCS X-bosoz, how does the sound compare? acliao Pass Labs 14 26th February 2004 12:55 AM
Bosoz lawbadman Pass Labs 5 14th July 2003 02:10 AM
10K Pot for the BOSOZ raincheck Pass Labs 13 20th September 2002 06:22 PM
Copyright ©1999-2017 diyAudio
