My Aleph-X compact PCB
Old 19th November 2005, 10:50 AM   #21
TS Lo is offline TS Lo  Hong Kong
Hi Bruno,
I'm interested in some boards as well as
power resistors/MOSFETs.
I'm starting to read those threads about Aleph-X.
BTW is VR101 200R??
Cheers
TS
Old 19th November 2005, 11:15 AM   #22
Carondimonio is offline Carondimonio  Switzerland
Carondimonio's Avatar
Hi all,
well, as for the input caps, no way!!!
They wouldn' t fit on this board even leaving the heatsink out, unfortunately PP caps are wayyyyyy to big. Using MKT caps would make things easier, but I' m not sure the sonic results would be as good as with PP...
TS Lo:
VR101 is 50K.
Bruno
Old 19th November 2005, 08:10 PM   #23
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by Carondimonio
Hi grataku,
hmmm... well, I' ll try to fit the input caps, I guess 2 uF should be OK, what do you think?
Hi jleaman,
the output boards are daisy-chainable, there are also pads for screw terminals with a 200 mil step for this purpose (and, of course, normal soldering pads).
As for the group buy, well... I do not know, it depends on how many people are interested.
Bruno
Im just asking if i can use 4 fets or less or do i have to have huge output stage ? I dont want a power ful amp maybe 20watts ?
Old 19th November 2005, 09:12 PM   #24
still4given is offline still4given  United States
still4given's Avatar
I believe 4 is the minimum. Have you looked at the Aleph-X Wiki ?
A lot is answered there.
Blessings, Terry
Old 19th November 2005, 09:20 PM   #25
Banned
Blessings, Terry
Thanks terry ill check it out.. ID like to build it and see how this compairs to the Aleph mini's that i love..
Old 22nd November 2005, 01:55 PM   #26
Default Version 5 - Input caps
Hi all,
well,version 4 has been trashed, don' t ask me why...
I redesigned the board completely and now I have found the place for two PP input caps
The two resistors between outputs and ground (33R 3W) will be mounted on the bottom part of the board, OR stacked above the big output resistors.
Any comments?
Bruno
Old 22nd November 2005, 01:56 PM   #27
Oh, yes... here' s the schematics (taken from Kristjan site):
Old 22nd November 2005, 02:08 PM   #28
Yes, I know, I posted the wrong one...
This is the one with mounting holes!
Old 22nd November 2005, 02:27 PM   #29
audiotux is offline audiotux  Germany
Hi Bruno ,
beautiful , i like it very much
very compact
maybe i use it as headphone-amp
Greetings from Germany
jürgen
Old 22nd November 2005, 09:18 PM   #30
analogair is offline analogair  Denmark
analogair's Avatar
Default Bruno
Great work. Nice boards you designed
analogair
air is analog
My Aleph-X compact PCBHide this!Advertise here!
Aleph-X Compact PCB Group Buy Carondimonio Group Buys 163 15th November 2008 05:32 PM
WTB: aleph-x compact PCB ashaw Swap Meet 0 23rd March 2008 08:24 AM
Compact supply.... notaclue Power Supplies 5 4th April 2006 12:33 PM
Compact sub DocLorren Subwoofers 11 8th January 2005 12:34 AM
Compact Aleph 5 module OliverD Pass Labs 22 19th March 2004 09:12 AM
