Old 3rd November 2005, 04:38 PM   #1
MikeW is offline MikeW  United States
MikeW's Avatar
Default Best Pass amp
Out of all the Pass amps built from this forum, which is your favorite?
What are you building now?
MikeW
Old 3rd November 2005, 05:26 PM   #2
SteveA is online now SteveA  United States
I've built an Aleph 5 (so it's my favorite for now). I have an Aleph 4 in process which means the main boards are stuffed and tested. I also have the chassis nearly finished. I have boards ready for the Aleph 2 as well. After that will come the Mini and the A30 and the Aleph X. Then I should be able to answer your question more fully.
SteveA
Old 3rd November 2005, 06:06 PM   #3
MikeW's Avatar
Jam how do your DIY's compare to your X-600's?
MikeW
Old 3rd November 2005, 10:02 PM   #4
mpmarino's Avatar
Hi Mike,
I like my mini better than my 30 for a few reasons. Mainly I think it sounds better.
I'm currently building a BOSOZ, all home done.(long project)
Next is an Aleph X with~ 31-32v rails and an old ~3kva EI traffo. My heatsinks are all saved up and um, I'm gonna use a lot of output devices. Probably a number somewhere in the magnitude greater than that of a Pass commercial amp! My garage heater doesn't cut it as I get older (longer project)
Mike, you suggested I make something big. Will that suffice?
Why on the axe spreadsheet does it NOT reflect a power increase at rails above around 28v. The sheet seems to max out around 144w into 8R. Do I have an old sheet??
Crazy Yankee.
Old 4th November 2005, 02:11 AM   #5
mpmarino's Avatar
D'oh..me<=idiot. You've got bump up the bias.
Crazy Yankee.
Old 4th November 2005, 02:17 AM   #6
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
The best amp is the amp that one finishes... and learns from : )
(i prefer my Aleph 2's)
((i learned the most from my Zen)
Old 4th November 2005, 02:58 AM   #7
winslow is offline winslow  United States
My favorite is my MiniAs...inspired by Pass.
They are my only Pass amps for now.
Old 4th November 2005, 11:25 AM   #8
MikeW's Avatar
I have built most of the Zens. Some of them sound pretty good. Most get taken apart for other projects. Good thing he goes step by step so he doesn't loose me. There is a lot to learn. Dual differential cascoded jfet bridged balanced single ended class A. Sounds like a new Aleph-X.
I still like the little Alephs (A3, Mini-A). I am sure there is something better on the way.
MikeW
Old 4th November 2005, 02:11 PM   #9
Account Disabled
Why don't you try F1?
With Aleph current source . . .
With a little bit feedback . . .
Hmmmmmmmm . . .
jH
Old 4th November 2005, 03:05 PM   #10
MikeW's Avatar
Has anyone done any boards for F1 yet?
MikeW
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Paging Mr. Pass, Mr. Pass pull my finger please. khundude Pass Labs 2 5th December 2008 04:11 AM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 03:10 PM
Amperes of Pass amps & Pass for ESL rick57 Pass Labs 3 4th August 2005 03:28 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
Page generated in 0.10651 seconds (75.56% PHP - 24.44% MySQL) with 11 queries
