Old 31st October 2005, 08:13 PM   #1
Default Aleph 5 smoking
have just finish the PCB of my Aleph 5 from Kristijan and I have connected them to the power supply.
When I have turned the power the resistor (1 ohm and 221 ohm on the Irfp 244 ( R64-66 and R52-54 on Nelson shematic)) side of -34 volts goes in smoking. You can see on the high resolution picture.
I have checked all soldering and the polarity of the components (ztx 450, Irfp 244, Irf 9610, condensator) and everything looks good. I have checked all the value of all resistors and everything is OK. I'm really dissapointed. Is some people have an idea of the problem ?
On the power supply I use Tr = 2x30 volts 500 VA with 4 x 47000uf on each channel. I have without charge + 41.2 * 0 * -41.2 volts.
Is it possible the voltage was to high. Do you thing I need used 2.2 uH to reduce the voltage or do you know an other possibility to go done the voltage around 34 V.
Could you help me
Old 31st October 2005, 08:51 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Although the voltage is high I am rather suspecting one or more shorted mosfets. Certainly when the 221ohm resistor goes up in smoke. What wattage are your source resistors?
/Hugo
Old 1st November 2005, 06:08 AM   #3
I use a 5W 1% to drive the source and a 0.5W 1% for the gate.
I don't invert the GDS connnection on the IFP244. You can see on the picture below.
Old 1st November 2005, 08:43 AM   #4
Netlist's Avatar
Unless you made a wiring error or a really wrong connection, a smoking gate resistor means a broken mosfet.
A variac and/or a 60 to 100w lightbulb would be real handy to limit the current at initial startup.
/Hugo
Old 1st November 2005, 05:13 PM   #5
wuffwaff's Avatar
it is very well possible that the fet was already broke when you put it in. You really have to watch for static charges. I always tough the earth connection from the mains before handling the fets. Never broke a IRFP240 but a few IRF610´s died while matching.......
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 1st November 2005, 08:08 PM   #6
Berry is offline Berry  Netherlands
First measure the voltage over the irf9610. If these are correct connect the irfp outut fets. The voltage is too high for the aleph5, but it will work for a while with a (big)heatsink.
Old 4th November 2005, 05:38 PM   #7
You can't believe that.
I'm really a poor guy (If I tell you) stupid, and what you want.
Do you know what is the problem ? Very simple, I have forgoten to put the isolate pad under the IRFP 244. Shameful.
Thank's everybody for your answer. Now everything It's Ok. I will be back in few weeks with the NEW BABY.
Old 4th November 2005, 11:48 PM   #8
Glad that you found the error. I love to see some pics from the complete amp.
Success
PS there are more Alpeh5 happily playing around with 40+ DC voltage.
Is that all there is?
Old 5th November 2005, 08:34 AM   #9
Yes, mine! (only just and without load)
Old 5th November 2005, 04:51 PM   #10
Running the Aleph 5 on 40V instead of 34 V , what do i have to change on the PCB ?. And how much power do i have by 4 and 8 ohm speakers ?
Berry
Smoking capacitors jdoorn Class D 7 23rd January 2006 11:32 PM
Zen V4 Smoking Q5 Diomedian Pass Labs 6 15th November 2005 02:46 PM
amp smoking biznatcher Car Audio 5 13th September 2004 11:48 PM
Smoking Amp jkramer Solid State 15 28th August 2004 04:17 PM
DOZ smoking? Kari Solid State 8 1st February 2004 02:40 PM
Page generated in 0.12106 seconds (73.26% PHP - 26.74% MySQL) with 11 queries
