Old 30th October 2011, 08:35 AM   #921
Vix is offline Vix  Yugoslavia
Vix's Avatar
Congratulations Zlati!
I bet that SEWA combined with a tube preamp is a real bang for the Buck! Hard to beat that price/performance ratio!
Nice
Old 30th October 2011, 09:27 AM   #922
Tyimo is offline Tyimo  Hungary
Thanks DJK for the info!
Tyimo
Old 30th October 2011, 05:07 PM   #923
Do you smell smoke?
Looks like Digikey does business in Hungary, don't know what the shipping cost/time might be though...
DigiKey Corp. | Elektronikai alkatrészek forgalmazója | Magyarországi weboldal
Roscoe
Old 30th October 2011, 11:26 PM   #924
tiefbassuebertr's Avatar
Originally Posted by cumbb View Post
Hello.
I suggest the same modification on the sewa as Ladislav Bunta did on the power Follower of Pavel Macura. The Bipolar Transistor. The sound will be more relaxed and fine:
Click the image to open in full size.C.
I have observe the same by my investigations. Where is going the online schematic in the meantime (Ladislav Bunta's homepage) ?
Hello.
The sound of the sewa in general comparision to the power follower of Macura (in my mind!):
It seems, the sewa has more „black“, more focus, he is more present and living, but he is a little bit restless, „brittle“, scruff.
The Macura seems to be more relaxed and quiet, more fine and clear, extended, but not so present and alive.
But this is only my experience!
Also this I can confirm. The reason are the lower values for the input-, output- and reverse capacitance of Ladislav Bunta's discrete IGBT resp. CFP/sziklai darlington.
Hello.my proposals:
Connect the grounds of the Q2 of the sewa.
Do not use channel separate PSUs. Never and nowhere. C.
I don't understand the advantages of only one PSU for both channels.
Now an other question: what are the audible sound differences, if there are V-FET's and SIT's in use instead normal MOSFET and discrete IGBT ?? Are there really additional great advantages in sonic quality by the use of this semiconductors in this both unity gain power followers?
check in this case also this thread:
First taste of Papa's new devices
Successors for V-FET SONY-Yamaha-TOKIN 2SJ28, 2SJ18/2SK60, 2SJ26/2SK76 and 2SK180
Originally Posted by zlati84 View Post
My amp works on 32V supply, 2.5 amps bias, temperature of the heatsinks is about 62 degrees C. ( Power is in a separate box)
What means that? Please let us know the heatsink temperature above the ambient temperature (or you know also the ambient temperature at those days).
My SEWA become to a little hybrid amp with big sound
The tube preamp is E88CC SRPP, made by this schematics
Attachment 173494
I want to know a solid state front end with a sound character as close as possible to that one of this tube SRPP topology.
Old 21st January 2012, 08:48 PM   #925
osscar is offline osscar  Latvia
osscar's Avatar
I have always wanted to try the SE SS amp. I have pair of ixys depletion mode Mosfets - but the PSU will be more expensive for high-voltage de-light amp, so i will go for Sewa with irfp 150 .
My SEWA is slowly being created, thanks to the author - for the PCB layout and circuit ! my progress in the attachment!
Old 23rd January 2012, 12:19 PM   #926
Jay is offline Jay  Indonesia
Relaxed sound is usually boring. Such is usually true with that kind of addition to the mosfet. Not my cup of tea I believe. Just a guess.
From your description of the sound, it seems you are comparing a Mosfet to a Bipolar. Actually I have built both amps at different times and so never tried to compare the sound, but I think I have the same impression about the sound.
I prefer to use a lower capacitance mosfet and intuitively select a better transconductance Mosfet (due to mismatch for example) to be put in the current source (bottom mosfet).
MAY BE the bipolar used in the current source will also have effect to the sound. I will try different types of bipolar anytime, to see if the sound "changes". I used a low Cob bipolar here, but have no idea with temperature characteristics.
Old 27th January 2012, 08:04 AM   #927
osscar's Avatar
Hi ,
I preform today the first Sewa amp (standard rev1 with irfps150 and bc 550c) tests (using positive rail from existing PSU in my F5 amp) . without the signal source is everything fine - bias approx. 2 A - 0.64V across Source resistors. But when i connected source (SS preamp or CD player) - bias immediately falls to 1 A or 0.3V across resistor and remains stable at 1A.when i disconcerting the signal source - instantly jumps to 2A.
I do not understand where there might be a problem
Old 27th January 2012, 02:34 PM   #928
Do you smell smoke?
Sounds like you either left out C2, or it's leaky....
Roscoe
Old 27th January 2012, 05:01 PM   #929
osscar's Avatar
Thank for the hint but i do not think that C is damaged - they are new and the problem is in both channels. Otherwise, the amp works and sounds good.I will try to take a look on output sine with scope.
Tube Pre Amplifier for SEWA 7 Watt ClassA MOSFET lineup Tubes / Valves 278 2nd June 2009 04:44 PM
Page generated in 0.11844 seconds (79.45% PHP - 20.55% MySQL) with 11 queries
