#481 | ||
What about on +24Vdc or even lower? Quote:
Tyimo |
#482 |
95dB =
![]() 24V would be ideal (18VAC trafo, loads down to 22,5V) for 4 ohm. With 2A bias it can do 8W. I would probably adjust the bias up a notch (as much as the heatsinks can take) 2,5-3A would be nice 3A will give you about 13W.22,5V, 3A=67,5W => 0,4C'W heatsink. With the IRFP250 you could get away with a 0,5'C/W (actual) heatsink, but it will be hot; 60'C But the mosfet will stay happy @ 67,5/2 x (0,65+0,35 (al-oxide washer+grease)) +60=34+60=94'C junction temp.
Mads K |
#483 |
EDCOR’s XSM transformers are not gapped.
I just redieved confirmation from the factory, OK to parafeed however. |
#484 | |
Just out of curiosity,do you have a schema how to do?Never done such a thing before.
Regards Åke |
#485 |
Thanks Mads!
These are good news. I will try! Tyimo |
#486 | |
This post is an example of parafeed, http://www.diyaudio.com/forums/showt...565#post986565 Parafeed is feeding a transformer through a capacitor and loading the plate with an inductor, not allowing the DC current through the transformer Here is a little light reading on the subject from Steve Bench http://members.aol.com/sbench/outstru.html |
#487 |
My long term plan is to build a bi- or tri-amped system
So here is the deal To be able to use SEWA I could build BOZ as pre, and have multiple outputs - one with fixed full gain fore SEWA, and others with adjustable gain Main attennuator on input could be a seperate TVC or simply a build in att PROBLEM ? I recall to have read that PASS pre need main attennuator on output, with regards to stability ? Comment on this, please |
#488 |
tinitus, shure you can do that. I would probably just insert fixed attenuators on the inputs of the power amps with gain. Drive them in paralell from BOZ. Use a 10K stepped att or pot on input of BOZ. There is no stability issues without att on output.
Mads K |
#489 | |
![]() http://perso.orange.fr/jm.plantefeve/sche.html |
#490 | ||
Hi DIGORA!
Did you buid or listen it? You should translate the text: Quote:
Tyimo |
| Tube Pre Amplifier for SEWA 7 Watt ClassA MOSFET | lineup | Tubes / Valves | 278 | 2nd June 2009 04:44 PM |
