djk said:Were is the fan going?
Unless you saw that thing up into several pieces and stand them on end, you're going to need a fan (unless it's a really low power amp).
Do you mean my amp?About the heat that's covered.The amp is working at a voltage of 14,5 DC.We'll see how hot the sinks can get.
What about these ones?Tyimo said:Hi Meanman1964!
You will not need so big heatshinks. You will see.....
Greets:
Tyimo
I have a question for you.The output cap (10000µF) can it be changed by 6800µF or 8200µF?
Yes. 4700 is the minimum.
2x4.7000 would be a very clever solution. May be the sound would be a bit"faster".
I prefer the big sink,it looks nicer more body.That's my opinion.
Yes, but you will not need the electric fan. (sorry, in my last post I wrote "fun" )
Tyimo
Mads!
Would it be possible to modificate your original SEWA (the resistore loaded) to operate with dual rail supply? Also to operate without output cap?
Personaly I like output caps, but there are some people who not and I would like to show them the "differences".
Greets:
Tyimo
Greets:
Tyimo
Tyimo said:This one looks good!
When will you ready?!?
Greets:
Tyimo
I don't have my toroid yet,I mean the 2x12VAC;I do have one of 1x14VAC without load.I also was thinking to make a regulated supply with modules of Thel Audio.By this way I could use my 2x30VAC toroids.Do I need only 1 toroid?
What do you mean???
You can use one toroid with dual secondary 12V for "kvazi" dualmono" PSU, but toroid with only one 12V secondary is also enough.
Important: You need 150-200VA
Tyimo
Tyimo said:Do not use regulated supply!!
When will you get your toroid?
Tyimo
I've ordered them from Schuro in Germany.They didn't has them in stock,I've to wait 3-4 weeks?Why shouldn't I use regulated supply? www.thel.de
I used a 300VA and it gets kind of hot..Important: You need 150-200VA
Did you build the original Sewa and what voltage has your toroid?
- SEWA - Seven Watt Amplifier
