Hi Mads!
Thanks!
Unfortunately I have never seen any cascoded source follower circuit.....
Yes! But my 6 pieces Lovoltech JFets are in the trash box!
Would it be possible to use them for a JFet BOZ???????
Tyimo
Wow! You guys blow me away! Nice report Tyimo!
Thanks!
You would have to get smart and cascode etc like ZV9.
I think it is better to design amps that you can use parts that are already in the thrash box
Tyimo
Re: SEWA
http://www.diyaudio.com/forums/attachment.php?s=&postid=912796&stamp=1147286502
Just some resitance to dampen gound loops. It has since moved to the powersupply in form of a thermistor
hifryer said:OK, thanks.
what is the role of the 2R7 in the ground line??
cheers
Happy holliday,I had to stop snusa for healt reason.And to buy plenty of cheap SNUS
Thank you, I probably should stop too, but.... you know.
Tyimo said:Thanks MIKET!
What do you think, is it not too weak to drive a Mosfet?
Has it +/-20V out put? (on +24V supply)
Greets:
Tyimo
The circuit as drawn will have no problem generating enough swing in voltage and will have a gain of about 30. The output resistance should be sufficently low to drive the MOSFET.
Hy Tyimo
Thank you very much for your answer, I would be really very happy, if you could help me somehow!
My private e-mail Address: mystang@freemail.hu
I am looking forward to hearing from you!
Marietta
Marietta
- SEWA - Seven Watt Amplifier
