#11 |
The one and only
I don't usually bother with mounting the bias devices on the
output stage - I always run the whole thing hot anyway. Stability is provded by high bias, large sinks, big output stages, and large Source resistors. The amplifier typically has a slight positive tempco, but one it heats up, its quite stable. The bias circuit on the A40 was an effort to eliminate all adjustments on the part of the builder, and it seems to have worked quite well. You can do as well or better with a Vbe multiplier and a pot and some time. For replacement parts, you can use decent generic parts - there was nothing special about any of the front end parts, and the Darlington output devices were unusual only in the small value of the driver emitter resistance. You can replace them with the Motorolas or TIPs easily enough, or make them discrete.
#12 | |
I am about to finish Jam's Mosfet version of the A-40. Can you pinpoint the reason for the A-40 still being a cherished design ?
Not so much,.......if it says "ZM" in the corner. |
#13 |
That is a good sounding amp. Let me know what you think.
I may have to order some boards. Nelson has you elbow healed up?
MikeW |
#14 | |
Crazy Yankee. |
#15 | |
I guess you say that therminal runaway are caused by small heatsinking in class A/B.....and will be no problem when using heatsinking designed for A? |
#16 | |
http://www.diyaudio.com/forums/showt...046#post627046 Am i barking up the wrong tree, Mike ?
#17 | |
Jam is the design man. He just has a hard time building amps and going to the post office. He is an excellent cook though. Not a very good driver. Happy Thanksgiving Jam.
MikeW |
#18 | |
my mother has a poster in her house that reads " Martha Stewart would die if she saw this house, let's invite her over" Oh..sorry, that's off topic.
Crazy Yankee. |
#19 |
Hello, please tell us what pre-amp can be done to amp The Zen Variations - Part 4.
Thank you very much for your reply, I am new in electronics.
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Paging Mr. Pass, Mr. Pass pull my finger please. | khundude | Pass Labs | 2 | 5th December 2008 04:11 AM |
| TPP versus PSE. | GeirW | Tubes / Valves | 11 | 27th November 2004 08:55 AM |
| My opinion on Pass Labs and Mr. Pass (Nelson) himself | b_online | Pass Labs | 11 | 21st May 2003 12:39 AM |
| 2.5 way versus 3 way | Mos Fetish | Multi-Way | 1 | 6th April 2003 06:57 AM |
