Old 27th October 2005, 09:43 AM   #1
Stabist is offline Stabist  Slovenia
Stabist's Avatar
Default MiniA strange behaveur
finnally finished (almost) MiniA - tested it - it plays. Quite well indeed )
BUT - because of some noise in speakers (buzzing and annoying when no music) - I've decided to play with grounding a bit more ... And now I have strange powering on problem (
The layout looks:
- 2 mono home made PCBs (not from group buys) - original for Aleph5
- each at his heatsink
- common PSU - 1 trannie 12V-0-12V + 2x46.000uF/20V SPrague 36D caps
- kind of a star ground in the middle od the PSU caps.
1st attempt:
- to that star ground I connected signal gnd from input RCA, gnd for speaker output, connection to middle tap of the trannie and gnd for each PCB - so PCB had only 1 GND connection
buzz (
2nd attempt:
- I've moved the signal gnd form inputs to PCB - I have 2 different GND lots on PCB - one for PGNG and one for SGND - and so I connected them seperately
buzz ((
3rd attempt:
- SGND and PGND on PCB soldered together to the same lot
AND NOW - when starting up the amp - in the left channel for couple seconds -14,5V!!!!!!! at speaker outputs?!??!?!? (that's like full rail voltage) and then slowly falling down to few mV ... The other channel - a "power on short term spike" and normal operation ... ?!?!?
OK, resoldering back to "2nd attempt" version - problem remains?!?!?
Then I decided to discharge PSU caps by additional resistor - (without that the voltage at the output with amp shut down (but no load) settles at around 2,8V - and power it back - normal - short spike of few volts and down to 30mV ...
Power off and back on - again - 14,5V that stays for few seconds and then it normalizes ...?!?!?!?
OK, it was late - went to bed - this morning before going to work I tryed about 10 times
power on/off cycle - nothing - works normal - short spike (power on thump) and everything is OK ?!?!?!?
What is/was happening with my MiniA?!?
Old 27th October 2005, 05:40 PM   #2
wuffwaff's Avatar
try to test it with a 8 or 4 ohm load. If the peak goes down to 3-3,5V (from 14V) everything is normal.
I donīt think the earthing experiments have anything to do with it. Maybe you just didnīt notice it before......
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 27th October 2005, 09:19 PM   #3
Stabist's Avatar
Hi!
I just wonder - I'm a stupid or .... I gues I know what I've done wrong.
I have "stereo" power supply - and both channels were attached to it - but I connected test speaker unit to only one channel - and so - when powering up - a lot of strange stuff appeared - sometimes this 14V peak, sometimes normal ... sometimes something in between etc ...
Then I disconected the other channel from PSU - everything worked OK ...
Connected back (still without speaker) - again ...
But after adding another speaker to the other channel - after around 30 attempts - everytime I get small almost unoticable "thump" - and I measure around 1V of spike ...
SO!! - I guess it was just that the amp was not simetrical loaded - and because of common PSU - the result was that unpredictable powering on??
Old 27th October 2005, 09:44 PM   #4
Stabist's Avatar
Gee .. I think I now confirmed also the situation when poor speaker can get full voltage at power on - if the amp was turned on and off without speakers, shortly after the speakers were connected and amp is again powered on - then sometimes this occurs ... And sometimes not ...
SO - avoid such strange tests ...
Btw - I don't have in mind I noticed this with Aleph5 ...
Aleph5 (MiniA) in flames stighe Pass Labs 14 2nd May 2008 01:04 PM
1 channel of MiniA working - measurments Stabist Pass Labs 55 8th November 2005 07:51 AM
MiniA & BoZ integrated amp Stabist Pass Labs 8 11th March 2004 11:38 PM
Page generated in 0.09484 seconds (77.58% PHP - 22.42% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
