I'm on my third attempt at the Return of Zen amplifier, I think I found a flaw in my original circuit board. However, the picture doesn't make it clear. If you look at the schematic, it says one of two things: Connect R11 from -out to ground. Connect R11 from -out to the input capacitors. The latter makes more sense, and is the way I did it last time. However, since I failed on my first attempt, I'm doubting everything this time. I sent an e-mail to Nelson Pass. So, if he responds, I'll have a difinitive answer. So, first, what do you people think the answer will be? I would really like to etch the board today. Thanks, pixie |
#2 |
I assume you refer to the "Zen revisited". That R11 is the feedback resistor and is connecting from the output back to the input of the MOSFET, not to ground.
#4 |
Ok, thanks.
I etched a new board with a place for a jumper. So, I'm set. I didn't connect the jumper. All I have to do now is put the thing together and I'm ready to test it again. I built a function generator. And I have an oscilloscope. So, I'm going to be able to test it properly this time. Later, pixie |
| DBX 500 schematic | d3imlay | Solid State | 0 | 2nd August 2008 05:12 PM |
| F3 schematic | kenev | Pass Labs | 2 | 24th January 2008 03:24 PM |
| Need Six-pac amp schematic | Sarge | Tubes / Valves | 1 | 31st July 2004 08:30 PM |
| What do you think about this schematic? | DaveWeckl | Solid State | 4 | 15th February 2004 10:32 PM |
