Old 12th October 2005, 01:01 AM   #1
SteveA is offline SteveA  United States
Default Aleph P1.7 help needed
I assembled the boards (from Kristijan K) some time ago. Power supply was (is) providing the correct 60V. I couldn't get the preamp to play music. After a couple of e-mail discussions with Kristijan, I sent the boards back to him (can you believe it). He said all boards were functioning properly.
I am using DACT CT2 attenuators and a Grayhill selector switch (I have successfully built the BOSOZ preamp from AudioXpress boards, DACT attenuators and selector switch). My problem has been, as I said, no music out.
When I hook up a source (CD) to the input, I can follow the signal from the input to the output of the selector switch (and to the input of the attenuators). With the attenuator moving from "lowest" to "highest" volume setting, I see a corresponding increase in the signal (ie, a variable voltage at the output of the attenuator.
So it is no surprise that this signal appears at the input on the main board. The surprise (to me anyway) is that the signal doesn't seem to be able to find it's way to the output (regardless of attenuator position).
What could/should I do to get this preamp up and running?
Thanks,
SteveA
Old 12th October 2005, 06:44 AM   #2
smario is offline smario  Croatia
smario's Avatar
Send a message via AIM to smario Send a message via MSN to smario Send a message via Yahoo to smario
I've built Aleph P recently and it works fine. Check again your parts. Do you have the correct voltage on the electrolytes?
If I were you, I would disconnect everything (input selector, dact …) except preamp. Connect your CD directly to your +input, and ground your – input with wire. Connect 10k potentiometer to + output in the way that slider is your output pin, first end of the pot is connected to the + output of preamp and second end is connected to the preamp ground. If you turn the pot you must get signal on the slider. If not, something isn’t connected properly or some part is incorrectly placed or malfunctioned.
Old 12th October 2005, 12:44 PM   #3
BobEllis's Avatar
If Kristjan says the boards are working, my first thought is that you may be inadvertently shorting the outputs. (I have that Tshirt) Have you tried looking for a signal with nothing but your meter/scope connected to the board outputs?
If that doesn't help, what are the DC voltages at all pins of the gain devices (Q16 and Q19 on Pass schematic)?
Does the signal reach the gates of Q16 and Q19? (could you have miswired SW1? I don't know if Kristjan provides for this)
Old 12th October 2005, 02:15 PM   #4
smario, Bob-
Thanks for responding. I have a full wardrobe full of Tshirts. In answer to your first question, I have not tried this. I do have a signal generator, so I could send a signal that way and look at the output (what voltage signal should I use?)
I will check the voltages at the gates of Q16 and 19 and post them this evening (CDT).
Kristijan's board has SW1 but his construction manual makes no mention of it (in terms of anything on a BOM list). I assumed that meant I didn't need to be concerned about it. My knowledge of electronics is pretty limited so something that may be obvious to those "skilled in the art" is not obvious to me. That begs the question, should SW1 be used on this board and if so, what part should go there?
Thanks again,
SteveA
Old 12th October 2005, 03:01 PM   #5
BobEllis's Avatar
Well, if you haven't installed SW1, there is no need to worry about miswiring there. I believe it adjusts input attenuation, but you should be just fine without it.
Use about 1 V signal just to make thinks easy. If you are using a multimeter to trace the signal, set your signal generator somewhere near 60 Hz, since the meter's frequency response isn't likely to extend too high. If you are using a scope you can go higher. Try the "universal audio test frequency", 1 KHz.
Don't forget to ground the (-) input if your source is single ended.
Old 12th October 2005, 03:14 PM   #6
Hi Bob-
I have a scope (an old vacuum tube Heathkit given to me by my father-in-law who also is responsible for me having the signal generator) so I should be able to use the "universal" 1k Hz test signal.
Thanks,
Steve
Old 13th October 2005, 12:00 AM   #7
Default Voltages
Bob-
Kristijan uses a different part id wrt Pass schematic. Q16/19 on the Aleph, I think, correspond to T3/6 on Kristijan's schematic (http://web.vip.hr/pcb-design.vip/aleph-17.html).
At any rate here are my voltages for:
T2(L) 15.9, 32.0, 12.0
T3(L) 4.7, 11.9, 0.6
T5(L) 14.2, 28.5, 10.3
T6(L) 4.6, 11.0, 0.6
T2(R) 14.4, 28.9, 10.4
T3(R) 4.7, 10.4, 0.6
T5(R) 14.3, 28.8, 10.3
T6(R) 4.6, 10,3, 0.6
These are G,D,S voltages in each case. The measurements bounced around somewhat for T2 and T5 (RandL) but T3 and T6 were pretty steady.
I'll chase the signal thru the preamp after the ballgame.
SteveA
Old 13th October 2005, 12:24 AM   #8
BobEllis's Avatar
It looks like a little mismatching, but it should work. T2 and T5 are the gain devices. The mismatch results in the DC offset (voltage difference between the drains of the gain devices) but since the circuit is capacitively coupled it should have little impact.
Good luck tracing the signal through the circuit.
Old 13th October 2005, 01:13 AM   #9
Default Single ended
Hi Bob-
Forgot to mention, I plan on running single ended and the - inputs are grounded.
Steve
Old 13th October 2005, 01:25 AM   #10
BobEllis's Avatar
OK - You should be able to follow the signal from + input to thegate and then source of T2 through the 100R resistor - 2K pot - 100R to the source of T5 to the drain of T5. (as well as gate to T2 drain, but inverted)
Aleph Help Needed ! cloud Pass Labs 8 1st August 2008 03:01 AM
Little help needed on Aleph P1.7 culture Pass Labs 2 2nd November 2007 04:02 PM
Aleph / Aleph X PCB Help Needed Michael Rothacher Pass Labs 12 30th June 2003 01:03 PM
transformer voltage needed for Aleph 4 or Aleph 2 diy student Pass Labs 23 28th November 2001 07:54 PM
Page generated in 0.12072 seconds (79.18% PHP - 20.82% MySQL) with 10 queries
