help: Aleph x temperature sensitive
Old 10th October 2005, 10:11 AM   #11
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
1.try to set the bias (start with both (V1/V3) pots at 0 Ohm) . Both sides should have the same bias, youīll have to adjust them a bit as the bias changes during warmup.
2.Then set the absolute dc-offset to zero with V2 that setīs the bias through the diff pair. This should be done with the lid on the amp cause this is quite temperature sensitive. Adjust when warm (1-1.5 hours)
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 10th October 2005, 05:47 PM   #12
Berry is offline Berry  Netherlands
Thanx all, it looks like the problem is fixed. The output to te speaker terminals has now 9mv dc. From the -+ output to the ground 20 mv. There were some problems:
1 unbalanced - terminal connected to the groud without a cap.
2 the two resistors 2.2k changed to 4.7k
3 start point off v1/v2/v3 0 ohm, not in the center.
4 changed the irf9610 no heatsink, but mounted together(with an insulator).
5 changed the resistor of the irf9610 (not the differential pair) to lower the bias.
After building 2 stereo aleph 5 without any problems, this mono aleph x amp is finished(i hope). Maybe i will change the aleph 5 to aleph x high voltage .
help: Aleph x temperature sensitiveHide this!Advertise here!
Aleph X - mosfet temperature yoke Pass Labs 48 16th December 2006 05:06 PM
PCM1702 sensitive to ESD? klitgt Digital Source 11 14th February 2006 05:22 AM
operating temperature for Aleph Phill Pass Labs 9 22nd November 2005 12:06 AM
aleph 2 temperature MikeZ Pass Labs 18 15th November 2003 01:16 AM
Aleph Temperature Sweet Spot macka Pass Labs 12 21st March 2002 10:39 AM
Copyright ©1999-2017 diyAudio
