#11 | |
I will update the previously posted schematic with component values, then I'll update this thread. Before that, anybody interested can send me an email for values. |
#12 | |
Nice amp (I got similar idea). One thing I wanted to avoid in my desigh was use of separate supply for driving circuit and output stage. I would use 4 resistors to ground around Vgs multiplier to decrease open loop gain and increase linearity. Also I would adjust current from both current sources instead of changing values of drain resistors of diff pair. |
#13 |
congratulation !
I'm sorry ! Can anyone help me? A Aleph chanel uses one dual-volume . how can I adjust volume for 2 chanel ? thank you !
Justice for Victims of Agent Orange http://www.petitiononline.com/AOVN/Thank all of you! |
#14 | |
#15 |
I tried downloading the current version of EAGLE (4.15 Light). It could not open the files. I get the error “Load error 290 on file..bla..bla..”. Can it be exported into another format or can a screen image be taken?
Leve |
#16 |
If the files can be zipped down to less than 100k they can be attached here, and I'll have a look at them for you.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#17 |
Sorry, I thought that it will work. Tomorrow I'll post complete schematic with values in pdf format. Stay tuned
#18 |
Would it be possible to make the diff pairs out of j-fets. And if so would there be any benefits to doing that? The input impedance would be really high.
Do any of the mosfets making up the diff pairs/ccs have to be mounted for thermal coupling with any other part? This is probably better answered when we have part numbers. I thought this amp would get a much bigger response, it is the only AB x-amp that that will take a single-ended input. Plus the symmetry is very pleasing to the eye. Leve |
#19 | |
I think it will take off when more info comes along...
Crazy Yankee. |
#20 | |
Thanks you !
| b&w nautilus inspired speakers | ceebmoj | Multi-Way | 5 | 17th November 2008 07:07 PM |
| New project inspired by 'beyond Ariel' | jimluu | Multi-Way | 7 | 3rd May 2008 06:30 AM |
| Arro inspired, but with Seas drivers | sheggdal | Multi-Way | 3 | 1st March 2004 01:29 AM |
