Old 14th September 2005, 12:02 AM   #1
mr.lex is offline mr.lex  Sweden
Unhappy why this car amps?!
Hello guys and sorry for my bad English.
Why is it big different between channels???
I have 4 Macrom synthesis1000 evolution car amps, which I can adjust in an independent way. I have big difference in the channels. The left channel has more power, which the right channel has not. I mean the difference between left and right is about 3dB and it is a big difference. I know all amps have a little difference between gains but not 3dB! When I adjust the left channel about 11 o'clock and the right channel about 2 o'clock then I have the same power. All my 4 amps have exactly the same problems, which the left channel, have more power and right channel have less power. These amps have a switch in circuit witch I can deactivate preamp and crossover and in this mode the amp is driven with a fixed sensitivity of 1.1V and the phase rotates 180' only right channel. (This mode because the sound quality will be the same as really home hifi amps) Therefore is important the right speaker output connection must be inverted. Now, I have no control over my input sensitivity gain adjustment and crossover. Both channel have the same output power. Which in this case it is correct. But I don't got it, when I have the switch on built-in preamp which in this case I activated input sensitivity gain and crossover the channels is different... This amps cost $1500 each and are very expensive. Now, Macrom say it is normal because into the pre-amp section there is an inverter circuit between channels, this circuit allows the mono configuration into the output speakers which I have very difficult to believe.
Thanks a lot if some guys can help me.
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 06:04 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 11:27 PM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 18 31st August 2006 11:39 AM
Why do some Bogan amps sound so good as guitar amps? amperex Instruments and Amps 7 22nd June 2006 12:46 PM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 02:33 AM
Page generated in 0.06262 seconds (78.21% PHP - 21.79% MySQL) with 10 queries
