Greetings friends,
It's been a while since i've posted here. I've searched online and it doesn't seem to be anyone that has built this amp. So i've decided to have one here on this side of the country. It's built much like my other Zen amps. http://www.geocities.com/lelamjade/SOX.html Note that Geocities may crap out the max. data transfer quota so all you have to do is revisit again later on. Does Nelson Pass's passdiy.com still accept projects on his gallery? Though i'm not sure if this amp is good enough to be on the gallery. Certainly no SoX i can see on there. BQ
Yellow People for a Yellow World Vote for Super_BQ, the Asian Alternative |
#2 |
Hi BQ,
I enjoyed your website. Thanks for documenting your work. Hope you get the time to write up how your amp sounds with different speakers. I've built a 16x bipolar output super-sym amp to drive low impedance loads with high dampening, and included a dual bias switch to keep the heat down during normal listing. I wanted one amp that could drive many different loads over the years, and this seemed like the best solution. I put the hi-low bias micro switch on the PCB for good electricals, and poke a plastic rod through a hole in the rear panel to toggle it. I no longer feel responsible for Global Warming...you may want more heat up in Canada! |
#3 |
Hi Super BQ,
are you using a variac? I seem to remember that at 40V rails, dissipation is around 640 watts/ch at 8 amps. Whats your bias set at? How do those resistors hold up? How does your X-Soz compare to your monster 25 watt SOZ. Im always fascinated when people build these things, now I just gotta build one. Nice Work!!!! John H. |
#4 |
Hi BQ,
Good to see a SOX in action. Welcome back. Dennis |
#5 |
Mega-amp: Yes the amp is Variac driven! 40V rails was not a problem at all. The problem is that air core inductor can't handle that much current over the hours. My bias is set as noted in the v6 article = 8 amps (4A each)
100 watt Caddocks are holding very fine. I always plan for extra heatsinking so I don't expect any problems with these parts. I don't know if anyone has documented the sound between wirewound power resistors vs. power film types. Perhaps the non-inductive nature of power films would be hands down better. BQ
#6 | |
The one and only
| audio nirvana super 10 or super 12 | tonytex | Full Range | 11 | 4th September 2011 11:55 PM |
| Nirvana super 8 and cast super 8 how do they compare to 206E? | freddi | Full Range | 4 | 22nd October 2010 03:29 AM |
| Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) | hollowman | Power Supplies | 44 | 7th October 2009 08:01 AM |
| FS: SUPER CD PRO KIT with SUPER SHOCKPROOF | bbp | Swap Meet | 5 | 17th April 2009 06:09 AM |
| Page generated in 0.09025 seconds (75.67% PHP - 24.33% MySQL) with 10 queries |
