Old 27th September 2002, 05:47 AM   #11
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
What's the heatpipe?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th September 2002, 07:28 AM   #12
Hello all,
I found my heatsinks at a scrapyard, they take apart all sorts of electronics and make their money off the aluminium (or the copper, stainless steel or plain steel, depending on what they take apart.
The guy at the scrapyard told me that he came across "things" like that often.
Well, from the looks of it I think they are from some sort of power supply or controller.
Size: 200mmx370mmx40mm (2 pieces). I had to pay 3 Euros per kilo. 2 Heatsinks weighed 7 kilos, so that's 20 Euros (I did some haggling, not very much though).
Greetings,
Jarno.
Old 27th September 2002, 08:00 AM   #13
miguel2 is offline miguel2  Portugal
There are a lot of ideas here. I have to say that this idea come after seeing the "lotusblossom" webpages (thanks Carpenter). I just turned it 90º to have bigger fins and not to drill so many holes. I agree with the questions you raise about surface contacts lowering the heat transference. But I find hard to accept that the square tubes between the fins don't do the job. Aluminium has a very high heat conduction and the limiting process should be in the surface contacts - that is why I chose 2 cm tubes. The heigh of the chassis can also be increased to get more heat dissipation (under reasonable limits...).
But I never done heatsinks before so your opinions so I guess I 'm biting my nails
BTW I am from Portugal.
Old 27th September 2002, 02:37 PM   #14
Paper mache horn fabricator
carpenter's Avatar
Default bars vs. tubes on DIY heatsinks
I think of the spacers between the fins as a pathway for the heat to travel. The trapped air in the center of the spacer tubes acts as an insolator and restricts the heat's path to the outer perimeter. The bar stock is capable of transferring more heat. This could be likened to pedestrians trying to cross a fenced court yard on a small, surrounding sidewalk. If the center of the court yard is accessable more people can cross.
I'm not an engineer and this is just the way I view things.
On the flip side: A chassis on Pass Labs was constructed using tube spacers and seems to be working well.
John Inlow
Old 27th September 2002, 02:55 PM   #15
Peter: A heatpipe is generally a hollow tube, often copper, filled with a liquid that vaporizes at relatively low temperatures. Basically one side of the pipe is where the liquid becomes a vapor. As it absorbs heat it becames vapor, and moves to the other end of the pipe, where it condenses, releasing heat on that side of the pipe. So you would mount one end on your transistors, where it would asorb the heat, then carry it to the other end where your heatsinks are, where it would release the heat. The concept has been around for a long time, often in heating/cooling system, however the decade or so they have been using the concept in high-end servers, and lately the computer ethusiest market, making it easy to get heatpipes of varies sizes and types these days.
And no, I can't spell, and my grammar sucks.
Old 21st October 2002, 01:44 AM   #16
carpenter's Avatar
Default my Aleph 2 chassis
Here's a mono block chassis. Dimensions are roughly 19" x 24" x 7". Fins are 5.25" x 5.0" each.
Old 21st October 2002, 02:43 AM   #17
fcel is offline fcel  United States
Carpenter,
How about some more pictures showing the close up of some of the details? Is this the 1st one that you actually built of your own design? Looks nice.
Old 21st October 2002, 03:15 AM   #18
This is one cool (running) chassis.
www.audiosector.com
Old 21st October 2002, 04:33 AM   #19
carpenter's Avatar
Default Second chassis
Thanks for the nice comments, guys. This is my second chassis and the second design. The first design was fabricated for the original Zen. You can find that design on my web page.
John Inlow
Old 21st October 2002, 07:03 AM   #20
hifiZen is offline hifiZen  Canada
hifiZen's Avatar
Default heatpipe
Hmm, neat idea... just the opposite of how a refrigerator works. I guess the downside is that there's a slight efficiency loss, since the heatsinks will always have to be cooler than the transistor mountings in order for it to work. Ultimately, it would still be better to mount transistors directly to the heatsinks, but a heatpipe sounds like a good way of transporting heat around...
- Chad.
To-3 Heatsinks sandstorm33 Swap Meet 8 6th February 2008 04:33 PM
about heatsinks bigpanda Solid State 2 4th May 2005 03:34 PM
Heatsinks DD_Davo Chip Amps 2 13th April 2005 01:00 PM
Heatsinks Peter Daniel Swap Meet 19 3rd February 2004 11:08 PM
Heatsinks for DoZ ultrachrome Solid State 0 4th February 2003 09:23 PM
Page generated in 0.12462 seconds (81.25% PHP - 18.75% MySQL) with 11 queries
