The one and only
I got this in the mail:
Quote: The green class A For the first time in history - true class A runs with high efficiency Introducing CSS(tm) the patented semiconductor class A circuit True. Over the years, countless attempts have been made to design true class A circuits with a reasonable degree of efficiency. None have been successful. Until now. Crystal Sound System (CSS™) is the name of a new and patented class A transistor amplifier circuit which combines the high linearity and accurate sound of class A with the high efficiency of class AB. The circuit is ingeniously simple and brings the sonic performance of audio amplifiers to a higher level than previously possible, without sacrificing efficiency or producing excessive heat in the way that traditional class A designs do. Due to it's simplicity, the CSS(tm) patent can be applied to virtually all applications now using class AB amplifiers, including everything from integrated circuits to high power public audio, with only minor alterations to the original design. The result is a more linear and accurate sounding amplifier, which puts less stress on the power supply and reduces high frequency interference, while retaining the stability and high efficiency of the original design. In every product where audio quality is of concern and an amplifier is present, CSS(tm) can dramatically help improving sonic performance without affecting manufacturing cost. :Endquote |
#2 |
The one and only
Here's the rest:
Quote: The amplifier includes a transistor pair (T1, T2), whose effective emitter is connected to the output (OUT) via a resistor (R1) in parallel with a diode (01). A constant load circuit, consisting of a second transistor pair (T3, T4), a resistor (R2) and a bias circuit (T5, R3, R4) is connected between the negative supply (VEE) and the output (OUT). The constant load circuit includes a shunt line between the emitter of the first transistor (T1) and the base of the second transistor pair(T3, T4). This shunt line has a bias circuit (T5, R3, R4) which is adjusted so that the output diode (D1) will not conduct when the amplifier idles. The constant load circuit ensures that a current continually flows through the output resistor (R1). The current through the first transistor (T1) will always exceed a lowest value and due to this, T1 will constantly operate in a delimited, generally linear part of it's working curve. The first transistor (T1) can handle both the positive and the negative polarities on the output. By definition, the amplifier is therefore a class A design. :Endquote They have email: info@tunerlux.com |
#3 |
I didn't try to send e-mail
I'm usually leery of unsolicited info that comes in the mail. When it comes to hard copy spam and spam, I'm a skeptical cynic. Except on even numbered weeks. Those weeks I'm a cynical skeptic. It really doesn't matter a whole lot if I lose track of which week is what. Do you think this has good potential ? Or is it more likely file 13 stuff? When it comes to circuits I'm still learning my ABC's - Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
#4 |
Banned
Uh Oh looks like you're out of a job.
we will miss you Art |
#5 |
#6 |
Banned
Satire alert for those of you not paying attention
Art
#7 |
whois lookup on tunerlux.com reveals the following:
Domain Information ================== TUNERLUX.COM (DOM-65939) TunerLux AB, Ekebybruk a1, S-75275 Uppsala, Sweden Sweden Created : June 13 2002. Last Updated : June 13 2002. Expires : June 13 2003. Admin Contact ============= Hazelius, Christian (NIC-67252) TunerLux AB, Ekebybruk a1, S-75275 Uppsala, Sweden Sweden Phone : +47 85 06 10 00 Fax : +47 85 06 10 00 Email : c.hazelius@telia.com Technical Contact ================= Carambole registry (NIC-31395) Carambole Sweden AB, Box 5274, SE-65 005 Karlstad, Sweden Phone : +46 54 17 63 63 Fax : +46 54 17 63 90 Email : registry@carambole.com Billing Contact ================= Carambole, Invoice (NIC-31396) Carambole Sweden AB, Box 5274, SE-650 05 Karlstad, Sweden Phone : +46 54 17 63 63 Fax : +46 54 17 63 90 Email : invoice@carambole.com Domain Name Servers ================== NS-01.CARAMBOLE.COM (NS-819) 213.180.68.130 NS-03.CARAMBOLE.COM (NS-821) 213.180.65.27 NS-02.CARAMBOLE.COM (NS-820) 213.180.68.131
- Chad. |
#8 |
Banned
But what the hell:
Where they are located says it all. Open up the sin bin...... Jocko |
#9 |
I haven't read Nelson's patent on the Aleph current source, but boy, this looks dangerously close to an improperlyn granted patent, or downright infringement.
So is this a joke, or what? Who would be silly enough to send such an advertisement to the man who owns what may very well be a prior patent on the same thing? I'm baffled! If this thing is real The fly in the ointment is that defending a patent can be a major PITA, actually, an expensive PITA... Nelson seems admirably calm... I'd be right pissed if it were my patent! But I guess this isn't the first time NPs had to defend his IP... the price of being an innovator (unless, of course, your Bill Gates, in which case you don't actually have to innovate, nor defend yourself from competitors you can just buy or strongarm into bankrupcy, depending on how you feel that day! hehe).
- Chad. |
#10 | |
![]() OMG this forum's been entertaining lately...
- Chad. |
| Mod By Mail? | planarboy | Analog Line Level | 0 | 11th May 2008 01:17 PM |
| Page generated in 0.11470 seconds (83.34% PHP - 16.66% MySQL) with 11 queries |
