#101 |
Try to switch the power supply's, So you know if the supply is ok
#102 |
Hi there!
He berry, they are both working now, the channels, it was not much what was wrong, but one part can do anything wrong, from the left channel it was only Q5 and from the other it was only the 1 ohm resistor only now we have to try it with loudpeaker on it and measering if there is difference between the channels. The transformers are realy loud humming. We wil see what we can do on it. I'll let you know. I am a happy guy now. |
#103 |
Teake,
That's the best news in weeks. ![]() Congrats. What transformers and VA ratings did you use? /Hugo |
#104 |
Hi Netlist!
Thanks for your reply. I use dubbel mono, two trafo's from 300VA, 2x25v, 6 amp each, one bridge rectifier for each mono-side, for each mono-side i got 2 x 47000UF. On both rails I got 32volt. greetings Teake |
#105 |
Would you think the hum is related to the current they deliver?
Do they hum when you disconnected the secondaries? /Hugo |
#106 |
you could try a dc filter for your transformers (helped in my Aleph 5 (600VA trannies, 25V, 2.5A bias)). If this doesn´t help you can try to decouple them mechanically. If this doesn´t help you are as far as I am in my Aleph-X and will probably have to buy new (bigger and better) transformers or place your amps in another room..... William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#107 |
he william
Thanks I will try this items. You will hear! Greetings teake. |
#108 |
What transformers do you use (amplimo/conrad). I use the schuro transformes (Germany), but they also make a humming sound. I also use a DC filter, but without succes.
How can you decouple them mechanically ? |
#109 |
1) I was also going to ask what does it mean by mechanically decouple the transformers? Would installing transformers on steel chassis causes more hum?
2) DC filters ... that is to be installed on the primary side of the transformers, right? Any example (link?, pictures?) of a commercially available DC filters? |
#110 |
http://www.euronet.nl/~mgw/homepage/uk_index.html
Nice link in dutch and englisch for diy cabel filters ! |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.09634 seconds (76.06% PHP - 23.94% MySQL) with 11 queries |
