Old 19th August 2005, 06:42 AM   #21
flg is offline flg  United States
flg's Avatar
After searching for a reasonable inductor for my Pi filter and finding the prices a little steep, I tried 1 thing that seemed to work for low currents(a few amps). People like Coilcraft make these common mode inductors. They are designed to bridge a power supply input and block EMI (Unwanted high frequency). They are specially wound to to influence the AC line with something less than 100uH. Virtually nothing to the 50/60Hz line. But, any signals appearing at the AC input in common mode, see's many mHs. I think the particular 2 of the 3 they offer were something like 4.5mH and 1.5mH. They do offer 1 with a 20mH common mode L but the current/saturation is to low for this type of application. The winding of these things is a little weird. If you can measure L, there are various ways of series/parrellel that produce unexpected results but it worked. They should not be to hard to find at the Coilcraft www site.
Another idea might be close to what I read here earlier??? the PC power supply people use something like a 50mH at the input to improve power factor. When I saw them I grabbed a few but I havent tried to test them yet. They should be good for about 2-3A and these power supplies are junk to most hackers.
I did however give up as I wanted more I for my design. I went to E-Bay and found a 20mH 10A hammond unit for $15 +SH.
FYI,. I'm using 2 - 39,000uF going into the inductor and 2 - 39,000uF coming out for a cool unmeasureable 47 single ended Volts...
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 19th August 2005, 08:53 AM   #22
Default And what did the Master do?
This is what Mr Nelson uses himself in the XA 160 amps.
A ferrite core. And it looks three times as small as the air core I use myself.
(Sadly this is not my own amp. Still saving)
Old 19th August 2005, 09:29 PM   #23
And what did the Master do? Post #22
They look like standard iron cores. Those will be good enough for me.
Old 19th August 2005, 09:51 PM   #24
An inductor with more DCR has a lower q, the resistance damps the ringing. If your inductors and capacitors start really resonating youve got trouble, as mentioned by PRR.
Heres a fairly relavent link on the Damping of Power-Converter Front-End Averaging Filters
This was helpful. Earlier I mentioned shunting to ground but your link provides the right formulas. Moreover, I had not known about the CR leg that comes ahead of the C shunt. I will study this more over the weekend. Thanks.
After dealing with this power supply stuff, my guess is that those guys at NASA probably do know more than me.
Old 29th March 2008, 10:55 PM   #25
I recently bought a few 250va toriodal autoformers to play with.
Just for fun I hooked one up as a choke in a choke input filter.
I know it wasn't suposed to work but under a 1A load it preformed just like a "real" choke. Then I removed all the windings a real pain in the *** . The 3" core I uncovered was
wound from a continious strip of steel. Then I wound 58 turns
of #16 copper wire around it and measured ~10 mh.
Using a 18v center tap transformer, a pair of Shokey diodes, this
10mh inductor and a .25F cap I measured 7v into a 1ohm load.
When allowing for the voltage drop in the diode and sourse resistance in the inductor this matches the 9v X .88 = 7.72v
expected. The #16 wire did get slightly warm at this 7A load
them hot when loaded to 12A. but not bad for a salvaged
transformer core and ~ 8 feet of #16 copper wire. This may not
work with othe transformer cores.
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
air core inductor vs. iron core inductor WBS Planars & Exotics 5 7th May 2007 11:02 PM
Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer bmpa Parts 2 22nd April 2004 04:15 AM
AIR-Core Vs Ferrite-Core Inductor in Class-D amplifiers Workhorse Solid State 13 23rd January 2004 09:14 AM
Ferrite Core Inductors for Crossovers r_s_dhar Multi-Way 25 29th June 2002 05:32 PM
Page generated in 0.11536 seconds (75.05% PHP - 24.95% MySQL) with 11 queries
