diyAudio Moderator Emeritus
NP's Patent #4,107,619 is said to be "Statis" patent. A good-small amp is driving output loudspeaker with the help of bigger amp to give the current to the load.
Which Statis or Threshold amp schematic uses this Patent? The ones that can be found in this forum seems none incorporating this patent. Is it the same principle as Current Dumping power amps (Quad, maybe) ? |
#2 |
I don't understand the fig.2 in this patent.
I redraw this fig.2, and it seems device 59 is forming "Howland Current Pump" with Vc at R7 as the input. But I'm confused. In my thinking, R4 should be connected to VC (not to ground) and R6 should be connected to ground (not to VC). The logic is if Vc is positive towards ground, then the device 59 should be giving current, not sucking current. Am I wrong here? |
#3 |
The one and only
There were only a few amplifiers built that actually corresponded
to the diagrams as shown in the patent. They worked well, but were simply too complicated. A much simplified series was introduced as the Stasis 1, 2, and 3. There, a single complementary pair of followers was connected to the output stage, but drove current gain off their Collectors "Sziklai" fashion, and the whole thing was cascoded, so that the followers experienced near constant current and voltage. |
#4 | |
This schematic is made By Mauropenasa. In this schematic, R6 is the sensing resistor, and the more positive side of the sensing resistor is connected to (+) input of U1. In the statis patent, R7 is the sensing resistor, and the more positive end of this resistor is is connected to (-) of device 59. These 2 has opposite operation of the current pump, one gives current for positive sensed voltage, one sucks current for positive sensed voltage? Which one is the right one? |
#5 |
The one and only
Hmmmmm...
From a cursory look, I don't think it's the same, but I'll think about it when I get back from vacation. /pass/: has been at the beach for a week, and not thinking too deeply. |
#6 |
Hi Mr. Pass,
You are accessing this forum from a beach / On vacation. Beaches and smart brains are compatible. I would appreciate your answers more this way |
#7 |
How to use this schematic?
The (-)input of opamp block is to be (-)input of the current pump. The (+)input of the opamp block is to be (+)input of the current pump. IF the (+)input is more positive than (-)input, then the output is giving current or sucking current? |
#8 |
At risk of threadjacking, I would mention that similar benefits have been achieved by means of another patent by Dynamic Precision.
They use a class-B amplifier to drive the ground of a floating power supply that is used for a +/- 15V class-A amplifier. Effective result is 400W or so with class A sound and drive. Somewhat simpler to do as well. |
#9 |
DIY !
Off topic...: I think it's :
United States Patent 6,255,907 (international publication no # WO 98/05119) Arne K
Ars longa, vita brevis |
#10 | |
The one and only
| Patent pending? | InclinedPlane | Full Range | 10 | 29th March 2009 09:08 PM |
| Patent? What patent? | Taterworks | Subwoofers | 1 | 28th January 2009 08:55 AM |
| Supersym patent | Rescue Toaster | Pass Labs | 6 | 22nd January 2008 10:49 PM |
| Patent | ABJensen | Digital Source | 3 | 2nd January 2008 07:46 AM |
| Patent stupidity. | Circlotron | Everything Else | 36 | 11th December 2004 06:04 PM |
| Page generated in 0.10982 seconds (78.55% PHP - 21.45% MySQL) with 11 queries |
