#11 | |
The one and only
#12 |
DIY !
try this...:
http://patft.uspto.gov/netacgi/nph-P...S=PN/6,255,907 Arne K (don't know if it's the right patent, but I've been told that it is held by DP...)
Ars longa, vita brevis |
#13 |
The one and only
Ah, there it is. I see that they did not reference Sano's
patent, which may explain a lot. |
#14 |
diyAudio Moderator Emeritus
For me (I'm not too fluent with English), the "Dynamic Precission" patent is 95% the same with Hafler's Transnova patent. It uses complete low voltage amp to drive grounded emitor output stages that modulates the floating supplies and the output is taken from the CT of the floating supply.
The feedforward/Error correction in Transnova patent is implemented as R (Ikorr) in this patent. |
#15 |
The one and only
I might be wrong, but I haven't seen the schematic and I am
guided by the quote "They use a class-B amplifier to drive the ground of a floating power supply that is used for a +/- 15V class-A amplifier" I don't think that this describes the Transnova (a nice circuit in its own right) because it describes two amplifier stages, a large one driving the supply of a small one. The only topology I know that fits is Sano et al, which was made by Panasonic. You might be amused to know that Sano's patent inspired me to reverse the roles of current and voltage and write patent #5,343,166
#16 |
Hi, Mr. Pass,
Yes, you are right. If only follows the quote (without reading the patent itself) the quote will be similiar to Sano's patent. But after I read the schematic in Dynamic Precission patent, I think it is more similiar to the Transnova more than to Sano's. BTW, what happened to your patent #5,343,166? You said you "wanted to save it for the old days". I always amazed by what you built/draw. When will you make something with this patent #5,343,166? From 7 patents of yours, (from the power amp categories) I think this one have the least implementation. |
#17 |
The one and only
I have never had occasion to put it in a product.
#18 |
The description of the circuit is accurate. I read a reverse-engineering bit on the product based on it somewhere.
The damn thing (DP A1) has more parts than a high-end class D amplifier, oddly enough, more transformers and capacitors than you'd expect if it were pure class A (2x800W @ 4ohm), and a very nice sound. Who says opamps have no place in high-end circuits?
| Patent pending? | InclinedPlane | Full Range | 10 | 29th March 2009 08:08 PM |
| Patent? What patent? | Taterworks | Subwoofers | 1 | 28th January 2009 07:55 AM |
| Supersym patent | Rescue Toaster | Pass Labs | 6 | 22nd January 2008 09:49 PM |
| Patent | ABJensen | Digital Source | 3 | 2nd January 2008 06:46 AM |
| Patent stupidity. | Circlotron | Everything Else | 36 | 11th December 2004 05:04 PM |
| Page generated in 0.09300 seconds (75.69% PHP - 24.31% MySQL) with 11 queries |
