Aleph 3 , Alehp-X
Aleph 3 , Alehp-X
Old 4th August 2005, 06:09 PM   #11
Angel Puerto is offline Angel Puerto  Spain
Hello,
For an universal amplifier of about 60w - 70 w in class TO my the suggestion that I gave him was:
I built a friend and it manages any speaker very well. You go on sure.
http://www.borbelyaudio.com/eb2000342.asp
Ángel
Old 4th August 2005, 09:52 PM   #12
GRollins is offline GRollins  United States
I'm always amused and amazed by how these rumors get started. Either the Aleph or the Aleph-X will do just fine with low-Z loads, assuming sufficient bias.
When I first started the original thread on the Mini-A, just about the first thing people asked was whether it would handle a 4 ohm load. In that case, no, I had not provided enough bias for 4 ohms, although increasing the bias is a pretty simple operation. So when I did the Aleph-X I made sure to boost the current so that it would (almost) handle 4 ohms. If you want more bias still, have at it. Just make sure that you have a robust power supply.
Grey
Old 5th August 2005, 07:22 AM   #13
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
i was just speculating, thats all...
as i recall (which could be incorrect), you can make an alephx that can be well suited for 4 ohm loads, but it would be HIGHLY inefficient and produce massive amounts of heat and have a very robust power supply. i just remember its better suited with 8 ohm loads.
just about any amp can be customized to work at different load ratings, some are just more suited for different applications.
im glad you are amused.
Old 5th August 2005, 07:33 PM   #14
Any amp biased heavily enough for a low-Z load is going to be less efficient, regardless of topology, gain devices, etc. The lower the load impedance, the higher the bias required, and the greater the heat generated at idle. If it's not used to produce sound, it goes up as heat, making the amp inefficient. You can't beat physics. All you can do is back off and go class AB or D or something, but then you're changing the rules of the game.
Grey
Old 5th August 2005, 08:02 PM   #15
ctong is offline ctong  United States
An amp becomes inefficient if you want to be able to drive both low and high impedence loads. The efficiencies for low impedence loads can be improved by reducing the rail voltage, but the amp will not be have enough voltage to drive high impedence loads.
CT
Aleph 3 , Alehp-XHide this!Advertise here!
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 27 11th November 2017 02:13 PM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 03:15 AM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 04:58 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 08:55 AM
Copyright ©1999-2017 diyAudio
