#11 |
ok,done!
the attached is the layout with wayne325s idea. P.S. all of these pdf file are draft version,I have not do a completed route check.when all things is done,I will offer a printable version for you guys.thanks for all interested Z' |
#12 |
very nice£¡£¡
#13 |
i have sent email for you¡£i need 10 suit these PCB ¡£
#14 |
Do you also now how to convert PCM to S/PDIF and back?
#15 | |
rgds Zang |
#16 |
Oke the problem is as follows:
I have an audio device and it has an PCM input output buffer. I'd like to transfer the PCM buffer directly into the computer using S/PDIF. So I have no loss of signal. So it stays digital. The PCM device has 4 wire: 1 - A Clock 2 - A Frame Sync 3 - Data in 4 - Data out I think I'm looking the wrong way, maybe it's easier than it looks like. |
#17 |
what your mean PCM is IEEE1394?I think 1394 is hard to convert to Spdif
#18 |
Digi01,
Do you have the PCB for Aleph P 1.7? I want to order one set(dual mono). Farl |
| REGULATOR PSU protel layout share | digi01 | Chip Amps | 30 | 3rd November 2008 04:36 AM |
| 3886IGC protel layout share | digi01 | Chip Amps | 16 | 7th June 2004 02:27 AM |
| Page generated in 0.09688 seconds (74.76% PHP - 25.24% MySQL) with 11 queries |
