#11 |
The one and only
Yes, those were 389's and 109's.
I think the "diamond" topology is more like this diagram, where you see the diff pairs operating push pull without limitation to the potential current they can deliver - they are biased at the Gates, not single-ended, and could operate class AB beyond the bias point. This allows for the current to deliver enormous slew rates. |
#12 |
The one and only
Actually, now that I think about it, you can get the Curl
circuit to do that too.
#13 |
http://www.diyaudio.com/forums/showt...823#post613823 Regards Adam |
#14 |
Nelson,
I see the schematic you drew as being the same as John's, just with Rs=0; i.e. each device running at Idss, which ain't that far a stretch, given that the biasing resistor is usually pretty small, anyway. Note that all bets are off if I'm mis-remembering the diamond circuit topology. For some reason, I'm thinking that I saw it drawn with the connections criss-crossed between the two differentials...probably just to confuse the issue. As I said, I regard it as being "John's circuit" regardless of other versions. One of these days I'm gonna buy me a JC-2 (regardless of phono EQ errors). I think the circuit's elegant and I like the way they look. So sue me. Your and John's pinky fingers know more than I will ever know about electronics, but that doesn't stop me from thinking the circuits are cool. Actually, come to think of it, I've got a complementary differential in the tweeter section of my current active crossover. Thanks, John. Grey |
#15 |
i really like complimentary jfet input stages too, just seems too elegant to not use! the thing that really burns my britches is the matching. i don't sleep well now because i measured the gains of my upper and lower diff amps of my Servo 50 years ago when I was building it. even though the jfets IDSS matched, transconductance clearly didn't, so the gains were slighty different (yeah, yeah, my wife calls me a nerd, too). that can't do anything nice to my distortion spectrum once I wrap global NFB around the amp.
what can i say, it's a complementary input stage, i want complements, d@mmit ![]() mlloyd1 |
#16 | |
The one and only
It seems to me that John's contribution consisted of the self- biasing of JFET dual differentials, not the notion of dual differentials as such. I can only go by the apparent 1974 release of the JC-2, and unless I am mistaken, the notion of dual differentials precedes that. If I am mistaken, perhaps John will comment. Such amplifiers as the Daniel Myers 'saurus amps and Jim Bongiorno's Ampzilla used dual differentials also, but you will note that in those cases the circuits were CCS biased. This means that they did not slip into a Class AB mode so as to provide more than the bias current. John did not intend such operation, as it is highly non-linear, and Sansui may have tarted it up for the occasion, but you'll recall that this was during the "slew-rate wars" of the 70's. Regardless of the details, the basic concept of the diamond differential (the not-the-Curl circuit) remains the same, but it's only value seems to have been for high slew rate numbers - running an input device in Class AB is not a popular approach.
#17 |
If I remember correctly also Yamaha made an amplifier with a dual differential input, each differential having its own current source like all the others do. So far nothing special.
The special thing is that they connected a big capacitor between the common emitters of both differentials (could have been common sources too, I don't know). Now you get the same class AB characteristics as mentioned above, to get really high slew rate specs. The charging current of the next Miller cap is not limited anymore to the value of the current sources. The capacitor allows for shifted DC biasing. Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973 |
#18 |
Nelson,
Mea culpa on the bipolars above. What with Olivia wanting to sit in my lap and my wife requesting that I fetch a bottle of wine for supper, my mind just interpreted them as active devices in the generic sense. My focus was on the hookup between the two differentials, not the differentials themselves. I already had the John/JFET connection, just didn't look at your schematic closely enough. Grey |
#19 |
The one and only
Well of course it was a test to see if you were paying attention.
#20 |
Clearly, I wasn't...not enough, anyway. (Note my reference to Idss etc. above. Sigh.)
Like the Shadow, wine has the power to cloud mens' minds. The mere mention of it is sufficient to flatten my brainwaves. At the moment I am drinking Le Grand Montmirail '98, a Gigondas (i.e. Cotes-du-Rhone, France--not my usual, since I lean towards Bordeaux, but hey, it pours and is tasty and that's sufficient unto the moment). Hence, anything I say in this post should be taken with a grain of salt. Grey |
| Choky Susy F3 for LU1014's | Tea-Bag | Pass Labs | 174 | 12th April 2012 08:16 AM |
| SuSy OpAmp => mixing amp | rkn | Pass Labs | 2 | 29th September 2008 09:21 PM |
| A Question about SuSy and the X2 | metalman | Pass Labs | 5 | 1st April 2005 03:55 AM |
| HELP Cannot read the Susy patent | akira | Pass Labs | 5 | 2nd December 2002 08:19 PM |
