Hi to you oll ... I have one question about power suplay capacitors... I'am building Aleph 4 or 2 ( don't know jet ) ... The question is ...
What is Computer grade capacitor and what is the diference betwin normal electrolitic ones ??? I found Philips 26000uF/75V caps but it doesn't say it's computer grade for 6.95 USD and I found on RS-electronic BHC 22000/63V computer grade for like 30 USD ...( it's big diference in price so I'am confused , I know the normal price is like 20-30 USD)...so whats the diference ? ...can I use those Philips or should I go for computer grade capacitors ? |
#2 |
Those Phillips caps sound like the ones Apex Jr. has. They are cheap because Steve gets great deals on the surplus he buys up. I bought a boxfull a while ago and think that they should be great caps. Cheers, Dan |
#3 |
As always though remember shelf life and check the manufacturing date.
/UrSv |
#4 |
So what is a acceptable shelf life/manuf date? I've always wanted to know.
#5 |
Yes I faund them on the apex jr... So than I should go for them...
Thanks |
#6 |
Well as far as I remember (and I could VERY well be wrong) RIFA specifies shelf life of PEH169 (excellent cap) to 10 years. I think I have read the same numbers from Nichicon. Personally I am reluctant to buy anything older than 5 years if is not dirt cheap.
/UrSv |
#7 |
I tested the 10,000uf caps in a 25+ year old SAE amp that I am rebuilding into a Leach amp, and they are still good. I charged the PSU up one day, and the next day the voltage was still pretty good (about 50% of full I recall), and I was able to spot-weld steel with them.
I seem to recall reading (from Mr Pass?) that older big caps frequently stay good even if they dry up. Cheers, Dan |
#8 |
Thanks for your replay people , but can you explain me what is computer grade capacitor ???
Thanks |
#9 |
I just went to apex Jr page ... and there it is ... with the big letars... Computer Grade ... Philips 26000/75V ...
I didn't see it firs time ... only that it's great for solid state amps... so thanks to you people out thare ones again ... |
#10 |
FYI.......
Computer Grade are caps that look like beer cans, either with the screw terminals or PC Leads, At one time they were in the older computers. There's also the snap in types that are a smaller version of the computer grades: And than the Radial and Axial Electrolytics. I won't forget the Disc's, Poly types, HV, and the variations from there. BTW...The 26,000uf 75V caps date code is 9235 35th week of 1992. Steve |
| Rebuilding a DAC Audio grade or Computer grade caps? | gto127 | Digital Source | 0 | 28th January 2009 09:17 PM |
| FS: computer grade electrolytics & polyprop caps | len_scanlan | Swap Meet | 6 | 31st October 2006 06:15 PM |
| F/S 80V - 100V Computer Grade Caps | Apex Jr | Swap Meet | 0 | 22nd September 2006 02:55 AM |
| Sprague 10,000 uF 75 V computer grade caps. | gnomus | Swap Meet | 3 | 8th August 2004 11:30 PM |
| PEH169 RIFA High performance computer grade caps | peranders | Swap Meet | 4 | 26th November 2002 01:54 PM |
| Page generated in 0.10459 seconds (80.88% PHP - 19.12% MySQL) with 11 queries |
