Old 17th September 2002, 11:12 PM   #11
The one and only
Nelson Pass's Avatar
Computer grade is a phrase left over from the good old
days of computing when they had linear supplies that
drew tons of amps all day long.
Nowadays they all seem to have switching supplies and
much smaller capacitors. The big cans are still readily
available, however industry in general has switched over
to PC mount snap in caps.
These work fine, but don't have the aesthetic appeal of
the big barrels.
Old 18th September 2002, 02:28 AM   #12
PedroPO is offline PedroPO  Portugal
PedroPO's Avatar
Send a message via ICQ to PedroPO
Is this what you are talkin' about?
I guess if today PC PSU used big dadies like this one they wouldn't crack up so often ( like mine, a week ago)
Pedro Oliveira
Old 18th September 2002, 02:30 AM   #13
PedroPO's Avatar
pic
Pedro Oliveira
Old 18th September 2002, 06:14 AM   #14
Here is another example of some computer grade electrolytics, in their "native habitate" none the less(and still working).
Old 18th September 2002, 08:28 AM   #15
kirc is offline kirc  Slovenia
kirc's Avatar
Need a picture of computer grade capacitors.
No problem at all.
See
best regards,
Leon
Music is a part of my life, DIY is my life.
Old 18th September 2002, 08:38 AM   #16
kirc's Avatar
Sprague on picture:
The 30,000uf 75V caps date code is 8008
8th week of 1980, and still has over 30.000uF capacity
best regards,
Leon
Old 18th September 2002, 09:34 PM   #17
Apex Jr is offline Apex Jr  United States
Default Computer Grade Caps
I see your picture; and the differance to think about is the
size. The older the date code the larger they will be.
I suspect your 30,000uf 75V cap is 3" Dia and about
5" high. My 26,000uf 75V are only 2" dia and 4 1/8" high
And there still making them smaller. Technology changes.
Steve
Apex Jr
Old 19th September 2002, 08:49 AM   #18
djk is offline djk
djk's Avatar
Small caps get hot. Not enough surface area on the can to get rid of the heat. The hotter they run the shorter the life. Check the specs for the ripple current ratings.
Old 19th September 2002, 08:49 AM   #19
kirc's Avatar
Yes, it's about 3.15" dia and 6.3" high.
Technology changes
best regards,
Leon
Old 19th September 2002, 12:21 PM   #20
Electrons are yellow and more is better!
peranders's Avatar
Has anyone held a RIFA (from Sweden of course!) cap in your hand? Shake them! What do you hear? Fluid inside which flows! The RIFA caps has lots of electrolythic fluid so they will last for a very long time.
To be short:
Computer grade:
Pros:
Can take very much current
Lasts long
Cons:
Expensive or very expensive
Big
Sonic properties, I have no idea.
/Per-Anders (my first name) or P-A as my friends call me
Rebuilding a DAC Audio grade or Computer grade caps? gto127 Digital Source 0 28th January 2009 09:17 PM
FS: computer grade electrolytics & polyprop caps len_scanlan Swap Meet 6 31st October 2006 06:15 PM
F/S 80V - 100V Computer Grade Caps Apex Jr Swap Meet 0 22nd September 2006 02:55 AM
Sprague 10,000 uF 75 V computer grade caps. gnomus Swap Meet 3 8th August 2004 11:30 PM
PEH169 RIFA High performance computer grade caps peranders Swap Meet 4 26th November 2002 01:54 PM
Page generated in 0.10097 seconds (77.09% PHP - 22.91% MySQL) with 11 queries
