Guest
If you don't need balanced inputs, balanced outputs or are having trouble finding a 4-gang pot, and want a non-inverting output then you may consider trying something like the circuit below.
It is a variant of BoZ with some of the features of BoSoZ. I gave it the name of KoBoZ - Kind of Bride of Zen. Tell me what you think. PS. The supply voltages and bias current reflect what I've got in my arsenal of spare (leftover) parts. Stan |
#2 |
Guest
C'mon guys
I can't believe no-one has posted a reply yet. I've seen sillier posts attracting more answers than this. Stan |
#3 |
My guess is that with a popularity of Aleph X project, everybody needs a balanced preamp these days.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 |
Account Disabled
Stani772577
I think your amp looks very nice. You like to invite more attention...? Okay, here is my silly question. What made you consider the differential amp for the unbalanced operation? How is the taste of the sound, red wine or white wine? JH |
#5 |
Guest
Hi JH,
Well, we all know about the advantages of diff amps - high CMRR, balanced to unbalanced conversion ability, etc. What follows is an extract from one of my old electronics books in regard to differential amps: " When operating as a single ended amplifier, the Q2(or the fet which gate is grounded in my case) common gate stage provides the voltage gain and Q1 stage provides the current gain. Since the whole circuit is biased by a current suorce, the voltage gain remains fairly constant over a wide range of frequencies. This, coupled with the fact that the common drain - common gate circuit has inherently good frequency response, results in a circuit characterizes by excellent voltage gain with high input and moderate output impedance and with excellent frequency response." Initially I wanted to build the BoSoZ, but have great difficulties finding a 4-gang pot here Down Under. Then I examined the BoZ project and thought it would be a good starting point, but did not like one aspect of it - its output is inverted, which means that somewhere else along the system the signal must be inverted again to be in phase with the input. I know, many people will say that the absolute phase is notso important, but I'm from a different school. Also the fact that I have no balanced sources or loads (read amps) with balanced inputs made me think about a simpler solution which will still achieve good results. I haven't built the circuit yet, building it at the moment, but considering its simplicity I'll probably have a prototype by the end of the week. The aim of my first post was to initiate a discussion about this circuit, about its pros and cons so to have a better idea whether I should go this path. That's about all for the time being, thanks for your response. Stan |
#6 |
The one and only
I don't think the 1n4148 is performing any function here,
so you should be able to remove it.
#7 |
Account Disabled
Thanks Stan for the kind explanation.
My short knowledge made me think only about the CMRR and its loss. Would appreciate if you post your successful result of the nice looking KoBoZ. |
| Bride of Zen r2 | zei | Pass Labs | 0 | 4th July 2007 07:43 PM |
| Bride of Zen | meanman1964 | Pass Labs | 12 | 7th April 2007 02:55 AM |
| Bride of Son of Zen for Mic Pre? | blschuler | Pass Labs | 1 | 16th October 2002 02:31 AM |
| Bride of son of zen -----> WHERE? | m60gpmg | Pass Labs | 6 | 23rd September 2002 09:08 PM |
| Bride of Zen, Bride of Son of Zen | 2Bak | Pass Labs | 4 | 12th May 2002 04:51 PM |
| Page generated in 0.09026 seconds (73.48% PHP - 26.52% MySQL) with 11 queries |
