Old 21st June 2011, 11:27 AM   #51
mr l is offline mr l  Australia
mr l's Avatar
finally finished my preamp, using teflon caps for the riaa. running the preamp off 2 sla batteries and using a meanwell switching psu as a charger. soundwise i'm impressed! sounds clean, noise floor higher but i can live with that!
Old 22nd June 2011, 10:12 AM   #52
Dzius is offline Dzius  Poland
Realy retro-tech design.
Old 22nd June 2011, 01:12 PM   #53
h_a is offline h_a  Europe
h_a's Avatar
By the way, I hope you use a moving iron pickup with that phono stage. Having a big mosfet at the input brings a large loading capacitance (Cis) that will roll of the tremble of an ordinary MM (remember recommended loading capacitance of the manufacturer! Usually quite a bit smaller than the Cis of a regular power mosfet.).
Otherwise, enjoy! Hannes
Old 23rd June 2011, 02:36 AM   #54
mr l's Avatar
hmm, I use a grado prestige gold mm cart, upgraded stylus, with no problems. this setup sounds far better than the commercial phono amps I've owned. almost matches my modified linn karik for sound quality. you could do a lot worse than a IRF610 when it comes to gate capacitance, the secret is proper biasing.
Old 27th June 2011, 11:33 AM   #55
gk7 is offline gk7  Europe
Grados are moving iron.
Georg
Old 28th June 2011, 12:46 AM   #56
mr l's Avatar
and? moving iron are a variation of MM. so, build the preamp and see what you think. i'll be trying MC cart next (with transformer of course).
Old 28th June 2011, 09:02 AM   #57
Like h_a already said in post #53 moving iron systems are (relatively) insensitive to capacitance loading, unlike MMs (and Transformers btw)
Georg
Old 28th June 2011, 09:43 AM   #58
mr l's Avatar
are you guys trying to threadjack? because I'm seeing nothing constructive. maybe it's time to build another preamp.
Old 25th August 2011, 09:46 AM   #59
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default MOSeiden phono stage
Built, playing now...
Sounds good, actually better than expected.
And less noise than expected too!
BUT, gain is a bit too low for my system, with passive/buffer-pre.
Maybe a single JFet in front would been perfect..?
( + another 6-10dB)
Arne K
Ars longa, vita brevis
Bride of Zen meanman1964 Pass Labs 12 7th April 2007 02:55 AM
New PCB for bride of zen maartentje Pass Labs 6 28th February 2005 07:19 AM
bride of zen renjiish Pass Labs 7 18th September 2004 05:32 PM
PCB for Bride of zen kirc Pass Labs 16 5th January 2003 05:16 PM
Bride of Son of Zen vs. A;eph P Peter Daniel Pass Labs 0 25th January 2002 07:45 PM
Page generated in 0.13127 seconds (81.21% PHP - 18.79% MySQL) with 11 queries
