Phono for Bride of Zen
Old 24th November 2005, 10:26 PM   #21
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
grounds?
these things are prone to baaad oscilations when ground is in a mess
you triple checked transistor's positiononing, resistors etc ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th November 2005, 10:29 PM   #22
Ila is offline Ila  Germany
Default Problem solving
Hi steenoe !
The pot is definitively not the problem. It seems that your power supply has difficulties in delivering the required supply current. Therefore you have some undesired coupling between the two channels and between the bias circuitry and the output stage.
Please use a 10000uF/40V cap near to the PCB.
Old 26th November 2005, 06:26 PM   #23
Alexander is offline Alexander  Poland
Hi Steenoe, i looked at image of your finished board and i think the left IRF shuld be turn around. Check it. I`ve just ended my board :-)
Alexander
Old 27th November 2005, 08:15 AM   #24
steenoe is offline steenoe  Denmark
steenoe's Avatar
You are right Alexander, thanks. I saw that earlier and it has been corrected. I will try and place a big cap close to the board as ILA suggested, and check my grounding scheme too. I am looking forward to hear what this circuit sounds like Let us know what you think about it, Alexander
Steen
Old 27th November 2005, 07:10 PM   #25
Default IRF 610 reversed
If you have reversed the IRF610, you have probably damaged T101/201=ZTX753. Please check the Vbe of this transistor, it should be around 0.65V. I know that well, because one day the same happened to me. The board still worked - sounding a bit strange. It turned out, that the above transistor had a Vbe of 1.3V. Unbelievable but true.
Ivo
Old 29th November 2005, 06:23 AM   #26
steenoe's Avatar
Thanks, ILA It works. It must have been the ZTX753 in the opposite side, I would never have guessed it could be that one I put in a new, and voila! Well, it actually sounds good too I didnt have time to listen a lot to it, but it sounds very promising. The supply I made isn't good enough, as suspected.
Its too noisy.
ILA, do you have any suggestions for a suitable supply?
Thanks for posting this fine, little circuit
Steen
Old 29th November 2005, 01:28 PM   #27
JC Fardo is offline JC Fardo  Brazil
JC Fardo's Avatar
Hi Steen!
Is this a BOZ dedicated RIAA board or can be used on other preamps? NS10? Yummm
Cheers
JC
Old 29th November 2005, 01:35 PM   #28
steenoe's Avatar
You can use it with other preamps also.
Keep in mind it runs from a singlerail supply, so if the preamp has dualrail supply, you propably have to build a dedicated supply for the RIAA.
Steen
Old 29th November 2005, 04:26 PM   #29
Default Power supply
Hi steenoe !
The power supply dependes on your application. If you use the board with the original BOZ board, I would suggest to tab the zener-diodes chain (the one that mister Pass likes best), take another TIP29 and dont forget the 100uF between base and ground.
My own solution is a good old LM317 as 25V preregulator, decoupling the output with a resistor - say 10 ohms or so - and then a bank of 10000uF capacitors.
Ivo
Old 3rd December 2005, 12:47 AM   #30
steenoe's Avatar
ILA, thanks for the supply suggestions. I made a kind of BoZ supply with 24V and it works allright! Well the RIAA stage sounds just great!! You can safely build that one if you consider to I have a small thing with hiss though! I didnt excactly excpect total silence, but the hiss is quite detectable! Between tracks at fairly high level, its not too good Any suggestions?
`Steen
Phono for Bride of ZenHide this!Advertise here!
Bride of Zen meanman1964 Pass Labs 12 7th April 2007 03:55 AM
New PCB for bride of zen maartentje Pass Labs 6 28th February 2005 08:19 AM
bride of zen renjiish Pass Labs 7 18th September 2004 06:32 PM
PCB for Bride of zen kirc Pass Labs 16 5th January 2003 06:16 PM
Bride of Son of Zen vs. A;eph P Peter Daniel Pass Labs 0 25th January 2002 08:45 PM
