Aleph Ono/ Xono
Aleph Ono/ Xono
Old 19th September 2002, 10:46 AM   #11
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
And it is a discrete Phono Stage I can say!
Peter, Why didn't you completely seperate the power supply, but only the transformers?
I see that you've split up some capacitors into a lot of smaller ones... Which C's did you split and why those?
Bouke
More Power Igor! More Power!
Old 19th September 2002, 01:08 PM   #12
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Aleph Ono/ Xono Send a message via AIM to Peter Daniel
I wanted to built it fast. The circuit was so small that I had enough space to fit PS (and it's separate for ea. channel). The caps were ROE 1000u, Sprague Extralytics and Panasonic HFQ 150u. I didn't even built an enclosure for 2 separate transformers.
If I would be doing it again I mount phono module directly on TT output, no interconnects.
To order kits contact me through forum mail.
Old 19th September 2002, 01:58 PM   #13
HarryHaller is offline HarryHaller  United States
Banned
Wink my interpretation of Ono
Where do I get the Free Sample brand caps. Those are my favorites! My next favorite are surplus.
H.H.
Old 5th October 2002, 01:39 AM   #14
transducer is offline transducer  Canada
Default Peter
Would you be willing to share your board layour for the Ono? I want to put one together.
Thanks,
RonS
Old 5th October 2002, 02:07 AM   #15
I don't mind sharing the layout. The board is only for MM amp with RIAA components outside, done p2p. The same for power supply. If you interested, I'll try to retrive from my other computer the layout. It was more than 3 years when I did it.
Old 5th October 2002, 11:38 AM   #16
1/137 is offline 1/137
1/137's Avatar
Send a message via Yahoo to 1/137 Aleph Ono/ Xono
If you run across that layout please email me a copy also....looks like a great project!
thank you,
rt
Old 5th October 2002, 12:43 PM   #17
Peter,
If it's not too much trouble to find the layout I'd appreciate it, although I think it's probably better to make a design where the riaa components are not off the board.
By the way, was it you who said that the Ono didn't need the output coupling cap if something in the circuit was matched or balanced??
RonS
Old 5th October 2002, 03:09 PM   #18
One reason I didn't include those components on a board was that anybody can use different size parts (I used MIT caps which are bigger than usually), the layout is simpler also. No DC blocking cap, I placed trimmer at differencial pair which adjusts the offset. I'll search today.
Old 5th October 2002, 03:14 PM   #19
Here's the picture of the PCB.
Old 5th October 2002, 04:05 PM   #20
Peter,
Can you elaborate on the trimmer on the differential pair? Do you mean that you put a trimmer in between the sources of the two halves of the sk389? If so what value did you use?
Thanks, and thanks for the photo of the layout, although I don't think I can do anything with it
RonS
Aleph Ono/ XonoHide this!Advertise here!
My Aleph ONO/XONO PCB veteran Pass Labs 9 6th March 2008 08:14 PM
aleph xono advise intense-tavda Pass Labs 10 23rd April 2007 08:31 PM
Coupling Caps in Aleph Ono/XOno and Aleph X0 rsbay Pass Labs 12 23rd November 2006 08:05 PM
