wanted :100W Aleph X (kari's board) bom/parts list
Old 7th July 2005, 11:59 AM   #21
dhole is offline dhole  United Kingdom
dhole's Avatar
Kari
In your parts list what are values of the resistors on the output boards of r1-3 and r4-6 please.
dave
The luminous space in the Sword of Orion...
Old 7th July 2005, 01:52 PM   #22
Eric is offline Eric  United States
Eric's Avatar
Dave,
Click on the tabs across the bottom of the spreadsheet. There are 4 tabs there...
Eric
Old 7th July 2005, 02:13 PM   #23
dhole's Avatar
Thanks Eric. I am using Open office so things are a litle different, i missed the tabs.
I think I will stick with Kari's onboard part list. It is generally the same .... I am concerned about a lack of diodes around the power input. There seems to only be oine diode on the board.
This projest is obviously more of a task than the Aleph 5s I ve just built. But Hopefully all will be ok. My concer at the moment is that I hope my fet matching is up to scratch. I matched the diff pair to 0.01vgs..... hope this is enough.
The next would be the tuning up at startup. I havent measured the dc offset etc on my aleph 5s so I guess I could start there....
I will have top read up on that... I dont have a scope though, not even sure if I need it for that......
best get reading....
thanks again everyone for your advise... Im sure I will be back very soon.
dave
Old 7th July 2005, 02:50 PM   #24
Assesears is offline Assesears  United Kingdom
dhole
The list states that r1-r3 on the utput board is 0.39
Yes your right mate should be 0.39R 3W(rs no. 294-2855) not 39R(rs no.152-381), using the schematic below from
http://web.vip.hr/pcb-design.vip/alephx.html
Old 8th July 2005, 09:50 AM   #25
dhole's Avatar
Has anyone out there finished An AX using Kari's boards ? I would be interested to see some pics and hear any comments on construction specs etc......
dave
Old 11th July 2005, 09:35 AM   #26
dr.strangelove3 is offline dr.strangelove3  Netherlands
dr.strangelove3's Avatar
I have a pair of Kari's boards and I'm gathering parts. I am very interested in what resitors (brands) are used by others. Which resistors are most important for sound quality. And for which can I use cheap ones.
Old 12th July 2005, 01:42 PM   #27
Eric's Avatar
I'm using Vishay/Dale 1% 1/4w metal film resistors from Mouser for all of my Aleph-Xs that are currently in progress. I ordered a number of each value and am carefully matching values across each side of the amp. There is a surpirsing amount of variability in the measured valued, so it is clearly a worth while effort.
For the a40 amp that I build a few years ago, I exclusively used Shinkoh Tantalum 1% 1/2w resistors and they all measured exactly spot on values - but they cost nearly $5 each (the Vishay/Dales are only $0.20 each).
Old 12th July 2005, 04:04 PM   #28
dhole's Avatar
does Nelson Matrch his resistors ?..
Old 12th July 2005, 05:33 PM   #29
Eric's Avatar
I don't recall reading anything that he posted about matching resistors. The Aleph-X that has developed here seems to be very sensitive to component selection - if things are not matched carefully, DC offset is a likely outcome. I have carefully matched resistors and mosfets on each side of the amp. Don't know the result yet, haven't built my power supply.
Nelson probably has a more elegant solution...
Old 12th July 2005, 06:27 PM   #30
dhole's Avatar
Eric
Are you using Kari's boards ?
dave
wanted :100W Aleph X (kari's board) bom/parts listHide this!Advertise here!
Wanted Vestax 46 Schematic and parts list/ repair manual djmike Chip Amps 24 12th October 2016 10:17 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
Wanted Vestax PMC 05 pro 3 - parts list/ repair manual Kid FX Chip Amps 0 28th September 2008 03:00 PM
Wanted: Aleph X main + driver boards designed by Kari Sander Swap Meet 0 27th September 2005 09:57 PM
Aleph-X parts list vdi_nenna Pass Labs 17 5th January 2004 05:43 AM
