I will build aleph 2 or aleph x (100w one), I still have to decide on this, because they have equal dissipation, and I will start building chasis..
So heres the question, how many of heatsinks in following pics will I have to use, will 4 be enough for one channel? (They measures 14cm X 18cm X 6cm) |
#2 |
another pic of 4 heatsinks that I will use for 1 channel if it will be enough (otherwise 6?).
#3 |
I'd say that 6 would be better. If dissipation of Aleph 2 is similar to A75 than you definitely need 6 per channel.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 |
I think dissipation is 300W..
#5 |
So 6 heatsinks is absolutely necessary for 300w dissipation (with longer life of devices in mind etc...)?
#6 |
I think so, but if you are not shure you could run calculations if you know specs for your sinks. It's pretty well explained in A75 article on Pass site.
#7 |
Dont know the specs, got them for free from a friend, I will use 6/ch. then..
#8 |
If you don't know the specs, two good options are...
Go to Aavid Thermalloy website http://www.aavidthermalloy.com/produ...products.shtml and use the search engine to find a group of heatsinks similar to yours. With some effort you can start to draw some conclusion about the likely rating of your heatsinks. Helps to measure yours and figure the area of heatsink per unit length. (in.^2/in. or cm^2/cm). Secondly, mount a power resistor to one of yours, dissipate some known amount of power (say, 20W), and measure the temperature rise. This is the best way to really know what you have.
Vince Harris |
#9 |
Thanks, that helped alot
| FS: Heatsinks for Aleph(s).. | skaara | Swap Meet | 2 | 29th August 2006 10:36 AM |
| are my aleph 2 heatsinks big enough ? | dhole | Pass Labs | 12 | 8th December 2004 09:25 PM |
| Heatsinks for Aleph 5 | tobias_svensk | Pass Labs | 2 | 15th February 2004 04:08 AM |
| Heatsinks - Aleph 5 | ElectroNick | Pass Labs | 7 | 13th December 2002 08:55 PM |
| heatsinks for aleph 2. | BrianGT | Pass Labs | 12 | 12th March 2002 06:59 PM |
| Page generated in 0.10213 seconds (74.11% PHP - 25.89% MySQL) with 11 queries |
