I recently built the Zen amp from the original article. No modification from the second article. What I'd like to know is- can I use a Thermistor to impede the in-rush of current to stop the speaker cone from extreme excursion at turn-on. Will this alter the sound in any way? What effects could it have on the amp? I don't want to add another circuit. I just want to keep it simple.
Any suggestions?? Thanks in advance for your help! |
#2 |
I've seen large capacitors used for this purpose.
Someone correct me if I'm wrong, but the capacitor will charge to the peak voltage then act as an open circuit. Something like a 3000uF capacitor should do. Don't take my word for it. I graduated three years ago and have been a digital programmer since then. My analog electronics is a bit rusty. Pixie |
#3 |
You can set up a relay to short the speaker outputs for a bit on start up. With the current source in the Zen, it won't hurt anything. If you set the relay closed with the power off and open it after a short delay, the thump will go away.
It is an additional circuit, but it does remove itself from the signal path when it is not in effect. This isn't my original thought. It was in a reader comment in Audio Electronics, I believe. Erik |
| Moscode 600 hum/turn off thump | MattV | Tubes / Valves | 17 | 9th July 2011 09:13 AM |
| turn off thump | jayme | Tubes / Valves | 6 | 23rd September 2007 07:40 PM |
| Aleph30 Turn-off Thump | hifimaker | Pass Labs | 3 | 3rd October 2006 03:27 PM |
| Leach Amp turn on thump? | wigginjs | Solid State | 5 | 1st March 2006 01:32 AM |
| Zen amp turn-on thump | robertpear | Pass Labs | 5 | 5th January 2001 12:23 AM |
| Page generated in 0.08188 seconds (71.54% PHP - 28.46% MySQL) with 10 queries |
