Zen amp turn-on thump.
Old 13th October 2000, 10:15 PM   #1
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Zen amp turn-on thump. Send a message via Yahoo to vdi_nenna
I recently built the Zen amp from the original article. No modification from the second article. What I'd like to know is- can I use a Thermistor to impede the in-rush of current to stop the speaker cone from extreme excursion at turn-on. Will this alter the sound in any way? What effects could it have on the amp? I don't want to add another circuit. I just want to keep it simple.
Any suggestions??
Thanks in advance for your help!
Old 16th October 2000, 08:06 PM   #2
pixie is offline pixie
Default Capacitor
I've seen large capacitors used for this purpose.
Someone correct me if I'm wrong, but the capacitor will
charge to the peak voltage then act as an open circuit.
Something like a 3000uF capacitor should do.
Don't take my word for it. I graduated three years ago and
have been a digital programmer since then. My analog electronics is a bit rusty.
Pixie
Old 22nd October 2000, 08:27 PM   #3
ebrewste is offline ebrewste
You can set up a relay to short the speaker outputs for a bit on start up. With the current source in the Zen, it won't hurt anything. If you set the relay closed with the power off and open it after a short delay, the thump will go away.
It is an additional circuit, but it does remove itself from the signal path when it is not in effect.
This isn't my original thought. It was in a reader comment in Audio Electronics, I believe.
Erik
Zen amp turn-on thump.Hide this!Advertise here!
turn off thump jayme Tubes / Valves 26 10th December 2015 03:50 PM
Moscode 600 hum/turn off thump MattV Tubes / Valves 17 9th July 2011 10:13 AM
Aleph30 Turn-off Thump hifimaker Pass Labs 3 3rd October 2006 04:27 PM
Leach Amp turn on thump? wigginjs Solid State 5 1st March 2006 02:32 AM
Zen amp turn-on thump robertpear Pass Labs 5 5th January 2001 01:23 AM
Copyright ©1999-2017 diyAudio
