Hello,
So, AudioXpress sells boards for the A-40. There seems to be active builders of the A-40 (?). What tranny are you using? I can't find a Signal 88-8. 2 custom pieces are going to run me a few hundred. If that's what I'm looking at, cool. But, I would prefer to know what (stock?) iron could be used. Thanks! Aaron |
#2 |
Signal doesn't list the 88-8 anymore but they do list an 80-8 that would do fine. However, their transformers are simply too expensive these days.
I've built 2 A-40's using the 88-8. If I were buying transformers for a new A-40 project I would buy 2 Avel 330VA 25-0-25 toriods from PartsExpress. They're $47.00 each. The voltage is a bit high but it gives you an opportunity to build a CRC or CLC power supply and then end up with the voltages you need. GL |
#3 |
Hi Aaron,
The Avel 330VA 25-0-25 toriods that GL recommends will do just fine for your a40 - one per channel. I had John from Victoria Magnetics custom wind a 600VA toroid for me with 4 secondaries, each rated at 24v 6.25A. I think it cost somewhere near $100. It gets a little warm after hours of use, so you might want to consider 350VA per channel. After rectification and 65,000uF of capacitance, I get rails that run at about 32v - a little higher than specified, but not a problem at all. I have a web page written up on my a40 with lots of construction details here: http://www.facstaff.bucknell.edu/esa...ovies/a40.html |
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 08:36 PM |
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 05:05 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 10:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.07503 seconds (72.06% PHP - 27.94% MySQL) with 10 queries |
